Will my tapered open ended wheel nuts that I use for my starmag wheels be OK to use with Weller's? Thanks
Weller Wheel Nuts, Will My Tapered Nuts Be Ok?
Minigirl
, Dec 09 2016 08:28 AM
7 replies to this topic
Posted 09 December 2016 - 08:28 AM
Posted 09 December 2016 - 08:37 AM
What size are the wellers?
Posted 09 December 2016 - 12:51 PM
Use std steel nuts with wellers. Dont use nuts for alloy wheels
Posted 09 December 2016 - 03:37 PM
Inspect the chamfer on the wheels and compare it to the chamfer on the wheel nuts. If is the same you can use them. If not then you can't. Simples 😊.
Edited by Cooperman, 09 December 2016 - 03:37 PM.
Posted 09 December 2016 - 04:57 PM
10x6
Thanks will have a look when they arrive
Posted 13 December 2016 - 07:36 AM
My tapered nuts seem to fit nice and snug into 2 of the wheels that have a different offset / deepness to the other two with no movement
The other two the nuts sit in and the hole does seem to have a taper to it but they don't sit in as snug as it did on the other two. Eg you could move the nut about abit like a joystick on a Xbox pad if you know what I mean
Posted 13 December 2016 - 12:34 PM
They usually use the original round nuts. These were used on the original steel wheels.
Posting a picture of a wheel will help but 10x6 wether they are triangle holes or oval hole wellers I would probable think they are as I have already stated
Edited by James_eaton_thewholething, 13 December 2016 - 12:37 PM.
Posted 13 December 2016 - 12:35 PM
