Morning, I need to change the box on my '92 SPI, would a slightly earlier 1275 box be compatible and the same diff/gearing?
1275/spi Gearbox, The Same?
Bryno
, Dec 09 2016 09:20 AM
4 replies to this topic
Posted 09 December 2016 - 09:20 AM
Posted 09 December 2016 - 11:08 AM
Any rod change box will physically fit (although you would have to use the relevant drop gears). In your case you are talking about a slightly earlier 1275 box so that would fit. I think the 1275 non Coopers had a slightly different final drive ratio to the Cooper versions.
Posted 09 December 2016 - 12:17 PM
How confident are you the replacement box is any better then yours? They all end up with the same faults through wear. Unless something majorly went wrong.
Posted 09 December 2016 - 08:36 PM
Not necessarily. A quality build and being selective (or corrective!) with gearbox cases can make a considerable difference.
Posted 10 December 2016 - 05:21 PM
Bits of mine came out with the oil, so I've either got to rebuild or just swap it for another complete unit, so I guess any non SPI box would be fine if I keep my diff.
