Deox Gel.... How To Use?
12 replies to this topic
#1 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 16 December 2016 - 08:17 PM
Hiya folks, bought some Deox Gel as its recommended on here, what's the best way to use it on car body corrosion?
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 15,900 posts
  • Name: Neil
Posted 16 December 2016 - 08:21 PM
Remove the loose rust as far as possible.
Apply the Deox gel liberally and do not let it dry out. Leave it for 1 hr then rinse off with water and thoroughly dry. I work mine it with a bit of scotchbrite as well.
#3 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 18 December 2016 - 01:00 PM
Perfect mate thanks!
#4 sonikk4
sonikk4
  • 15,900 posts
  • Name: Neil
Posted 18 December 2016 - 02:50 PM
I use a hot air gun afterwards to ensure its dry. I have used other products to clean off the residue but water works the best. The company recommends it so there you go.
#5 Steve220
Steve220
  • 4,896 posts
  • Local Club: BMC
Posted 18 December 2016 - 02:51 PM
Wire brush as much rust off as possible, apply liberally then cover it with cling film. Leave as long as possible for best results.
#6 pete l
pete l
  • 1,360 posts
Posted 19 December 2016 - 02:56 PM
Get a fine wire brush and rub the gel into the rust to get all of the rust out of the tiny little pits.
Edited by pete l, 19 December 2016 - 02:57 PM.
#7 Marco1972
Marco1972
  • 822 posts
Posted 19 December 2016 - 03:24 PM
Cling film method works well
If its really pitted a couple of repeat applications will be needed
#8 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 19 December 2016 - 05:35 PM
Thanks guys, we have a wire brush attachment for a drill, will use that :)
#9 pete l
pete l
  • 1,360 posts
Posted 20 December 2016 - 08:29 AM
That's probably too violent, you need a hand held wire brush that you can work into the rust and rust pits.
#10 tiger99
tiger99
  • 8,584 posts
Posted 20 December 2016 - 11:47 AM
Yes, the drill might spray it in your face! Not good... Please always wear at least goggles when using any kind of chemical. No eyes, no more driving your Mini. I would hate that to happen to anyone.
I assume that the manufacturer provide full instructions somewhere, perhaps on their web site? Having said that, the above suggestions all make perfect sense.
#11 MikeRotherham
MikeRotherham
  • 939 posts
Posted 20 December 2016 - 05:46 PM
The instructions,supplied on a separate sheet of A4, are very clear and detailed and i think it actually states to follow the instructions closely.
#12 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 20 December 2016 - 10:11 PM
Just to clarify I'd use the drill powered brush to clean the initial rust off, then apply the gel.... Then use a hand held wire brush to work in when needed
#13 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 20 December 2016 - 10:13 PM
I always wear necessary ppe
