Turbo Piston Rings
15 replies to this topic
#1 redmini
redmini
  • 262 posts
  • Local Club: Snowdon Mini's,Miniaddicts
Posted 16 December 2016 - 11:34 PM
I bought an engine second hand a few years back and have lost the build spec provided by the seller, I thought it was about time I put it together and put it in the car.  When I picked up the engine one of the pistons slipped down in the bore and the lower piston ring got stuck against the casting and couldn't be withdrawn.  Long story short, a local engine centre have had to break the ring to get the piston out and now claims he can't find a replacement ring.  I haven't seen the pistons but he said the numbers on it are 2150 +20 and 105 521 or 125S21, there are 3 rings per piston, can anyone help to locate the right rings please?
Edited by redmini, 16 December 2016 - 11:35 PM.
#2 MINI-TURBO
MINI-TURBO
  • 230 posts
Posted 21 December 2016 - 11:31 PM
hi im not sure if i can help or not but i have a set of rings that came with my 18cc dished forged pistons from MED +20thou as i brought the lightweight forged rings from MED seperately. if someone can confirm they do fit your pistons I'm willing to sell the rings that I'm not using
#3 MINI-TURBO
MINI-TURBO
  • 230 posts
Posted 21 December 2016 - 11:37 PM
are you sure its not 21250? they have them on mini spares, ill post the link but i think these are the ones for your pistons
http://minispares.co...ston rings.aspx
#4 mini13
mini13
  • 3,805 posts
Posted 21 December 2016 - 11:39 PM
The med piston rings will almost certainly be too thin, total seal can provide a ring pack for just about anything, and I know of people that have used them on metro turbo pistons.
#5 redmini
redmini
  • 262 posts
Posted 22 December 2016 - 11:30 AM
I've been to look at the engine as I have spend hours online searching and spent a few hours calling people with no success, so here's some pictures I took that now show the correct numbers.
21250 +20 ID5 S21.
#6 Northernpower
Northernpower
    Mr. 7-Port
  • 2,409 posts
  • Name: Graham
Posted 22 December 2016 - 12:00 PM
21250 +20 ID5 S21.
Minispares sell two types of rings for the 21250 + 20, if you follow this link http://minispares.co.../classic/piston it will explain the differences.
Edited by Northernpower, 22 December 2016 - 12:01 PM.
#7 redmini
redmini
  • 262 posts
Posted 22 December 2016 - 12:59 PM
21250 +20 ID5 S21.
Thanks Northernpower, I'll try them again now and see if I can get something sorted.
#8 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 22 December 2016 - 09:49 PM
The ring land looks broken or is it the pic? I would have thought new Pistons time if it's broken.
#9 Northernpower
Northernpower
    Mr. 7-Port
  • 2,409 posts
  • Name: Graham
Posted 22 December 2016 - 10:11 PM
Looking at the picture of the piston in the block it certainly looks like the casting is broken in the area between the gudgeon pin and the oil control ring. If that is the case, you'll definitely need a new piston.
#10 redmini
redmini
  • 262 posts
Posted 06 January 2017 - 12:09 AM
It's just the picture, all the pistons are the same.
#11 Northernpower
Northernpower
    Mr. 7-Port
  • 2,409 posts
  • Name: Graham
Posted 06 January 2017 - 12:18 AM
Wow, I'm surprised you say that, I've just had another close look at the picture of the piston in the block and it does look as though the casting is broken. Obviously you can see it, I can only see a picture. Good luck with the build.
#12 redmini
redmini
  • 262 posts
Posted 06 January 2017 - 11:47 AM
I'm currently away and the engine is still with the machine shop, looking at the picture on my phone it's a lot clearer and to be honest I have to agree with you, it's got me nervous and I hope they have insurance as I'm not forking out for a new piston!!!
#13 Gr4h4m
Gr4h4m
  • 1,802 posts
Posted 06 January 2017 - 11:37 PM
Hope you get it sorted.
#14 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 19 January 2017 - 11:16 PM
I think the gap you are talking about is normal, its the drain from the oil ring (it helps to lubricate the gudgeon pin), much like that overly large groove behind the oil ring on the thrust sides of the pistons. These are not performance pistons and I would refrain from using much more than standard boost levels or excessive RPM with them.
Edited by Sprocket, 19 January 2017 - 11:16 PM.
#15 Northernpower
Northernpower
    Mr. 7-Port
  • 2,409 posts
  • Name: Graham
Posted 19 January 2017 - 11:26 PM
It's difficult to see one way or another from the supplied picture and the op is away. He'll know as soon as he compares it to the others. It'll be interesting to see what the result is.
I agree with you, they're not a good piston to use in his intended application.
