1974 Biota Mk2
10 replies to this topic
#1 IvorBiota
IvorBiota
    Starting My Mini Up
  • 4 posts
Posted 01 January 2017 - 12:46 PM
This is my Biota Mk2,
It featured a Mini Magazine article in 1996 http://biota.jouwweb.nl/articles/mm and was resprayed blue in 2014.
Current Spec:
Engine - Modified 1275 (no engine number) with 11 stud 12G940 head. 731 cam. Weber 45DCOE. LCB exhaust with VW silencers.
Gearbox - Elf/Hornet early remote casing, ratios unknown, 3.44 Final Drive. Custom extended remote gearchange.
Brakes - Single circuit, Front - Cooper S 7.5 inch discs. Rear - Standard drums. No servo.
Suspension - Front - Standard rubber cone, Negative camber bottom arms. Rear - De Dion type axle with trailing links, anti-rollbar and coilovers.
Wheels: 5x12 Compomotive alloys fitted with Yokohama A539 165/60 R12
Work done to date:
New clutch slave cylinder.
New alternator.
Reconfigured the cooling system.
New combined water temp and oil pressure gauge.
Reconnected the rev counter.
Work needed:
New primary gear oil seal, new driveshaft oil seal - (expanding pool of oil on the garage floor!)
Things to do:
New seats or refurbish the original "clam shell" ones.
Reinstate the dashmounted gearchange.
Update the dashboard.
New steering wheel.
Replace rear coilovers with adjustables. (and softer springs!)
Tidy up drivers compartment.
Fit sender to fuel tank.
Check engine capacity and wear. Possibly get it on a rolling road. (Runs very well at the moment)
13" wheels?
More to follow.
#2 megamini_jb
megamini_jb
  • 5,197 posts
  • Name: Jamie
Posted 01 January 2017 - 12:51 PM
:wub: that is cool!
#3 minifreek1
minifreek1
  • 489 posts
  • Local Club: Northern Monkeys.....
Posted 01 January 2017 - 01:03 PM
Thats a lovely little motor and a refreshing change too....
#4 pdaykin
pdaykin
  • 508 posts
Posted 01 January 2017 - 01:07 PM
Very nice.
#5 Vic Price
Vic Price
  • 21 posts
Posted 07 January 2017 - 12:51 PM
Hi Ivorbiota, You mention rear shocks, I remember my first Biota had shocks from a Greaves trial bike, Which sounds about right as where the cars where made at the time there where many British motor cycle part suppliers especially down the road in Darnall.and Attercliffe.
#6 pdaykin
pdaykin
  • 508 posts
Posted 07 January 2017 - 07:31 PM
So was the kit made in Derbyshire/Yorkishire ?
If so, never knew that there were any local kit makers
#7 Vic Price
Vic Price
  • 21 posts
Posted 08 January 2017 - 06:08 AM
pdaykin, they where made In Dinnington  Sheffield,
#8 IvorBiota
IvorBiota
    Starting My Mini Up
  • 4 posts
Posted 08 January 2017 - 03:16 PM
The ones on my first Biota were Girling units intended for a BSA A50 or A65!
Not sure yet what is fitted to my current one, definitely a higher spring rate as it hardly moves when you get in, unlike the first one.
Edited by IvorBiota, 08 January 2017 - 03:20 PM.
#9 Vic Price
Vic Price
  • 21 posts
Posted 09 January 2017 - 08:43 PM
Interesting, my first one was quite solid on rear suspension, and was super on grip and cornering, not soft at all, But good handling. What reg was your first . and does it still exist?.
#10 IvorBiota
IvorBiota
    Starting My Mini Up
  • 4 posts
Posted 10 January 2017 - 05:41 PM
I'm just thinking this one is too solid. Just as yours the handling, roadholding of my first one was brilliant. Never once did the rear end step out of line despite my best efforts. Haven't had chance to try anything with the current one yet, it will have to wait till I get it on a circuit.
My first one was DFD697K and it is currently roadgoing. http://biota.jouwweb.nl/articles/ckc
#11 IvorBiota
IvorBiota
    Starting My Mini Up
  • 4 posts
Posted 13 January 2017 - 03:58 PM
My reconfigured cooling system with purpose made thermostat housing and swirlpot header tank.
The thermostat housing was designed to fit under the bonnet profile. My first Biota had a triangular plate with right-angled pipe sprouting from it pointing backwards - no thermostat. I wanted to go one better.
Mini Spares
