I'm just getting around to fitting my radio into my mini, I've welded up the hole in the wing so need a good quality and discreet as possible internal arial. any recommendations?
Best Internal Arial
Posted 02 January 2017 - 10:52 AM
Posted 03 January 2017 - 04:21 PM
Posted 03 January 2017 - 08:44 PM
http://www.ebay.com/itm/131648889210
I got one of these last Month.... Fitted it and seems to do the job perfectly.
Posted 29 January 2017 - 09:30 AM
Cheers guys forgot about this, I picked up one from halfords as it was cheap but not sure what it's like yet, I like the above might have to try that.
Posted 29 January 2017 - 06:00 PM
Using the heated rear window as an aerial worked very well on a Ford Escort I had that had it fitted as standard from new.
There were other makes and models that used the same technology.
It was possible to buy a kit manufactured by a company called 'Bifi' that achieved the same thing but I think no longer exists.
I think it would be a good solution if someone came up with a modern version.
Posted 29 January 2017 - 08:51 PM
Thats a pretty good idea
Posted 31 January 2017 - 07:49 PM
I removed the aerial from the front wing on mine, put a grommet in the hole and fitted a roof mounted aerial off a Corsa at the rear of the roof....
Although not an internal aerial, it works very well indeed, especially as its got an amplifier built into it....
