Boot Lid Sticking Out At The Bottom
Posted 05 January 2017 - 01:28 PM
Is there any way I can adjust this to make it sit closer to the body in the corners?
Its on a 73 clubman saloon, not sure if it's the original boot lid but I'm assuming they're all the same.
Posted 05 January 2017 - 01:33 PM
Posted 05 January 2017 - 02:28 PM
Might sound daft but are the hinges on the right sides ??
I remember this from an old post somewhere
Mark
Posted 05 January 2017 - 05:15 PM
Are the hinges after market or the original, some pretty crap ones out there
that don't close up properly. I bought some on evil bay that were rubbish
Posted 05 January 2017 - 05:42 PM
Posted 05 January 2017 - 05:46 PM
Has it had any work at all on the hinge panel??? or any rear end damage thats been repaired previously.
Posted 05 January 2017 - 08:41 PM
What is the gap in the centre bellow the number plate like?
It almost looks as if the curve across the boot is different to that of the body.
Posted 06 January 2017 - 03:10 PM
Looks too far out to be the gasket missing, but are they fitted to both the boot lid and the hinge panel?
http://www.minispare...ic/24A2175.aspx
Edited by Woody001, 06 January 2017 - 03:10 PM.
Posted 07 January 2017 - 10:48 PM
You mentioned you mounted the later type of seal--mounted to opening instead of boot lid? Can you mount that later seal type to the older
models that had the lid/clip seal?
If it made it harder to close, I'd watch the bottom as you slowly close and latch lid. -All that force of a new seal may be trying to overcome the hinge
mounting area below, forcing distortion/bending? That area of body may not be as strong as the reinforced construction of the boot lid--something's
gotta give. -Just a thought
