Anyone Fitted Cobra Fia Historic Seats?
Posted 07 January 2017 - 12:17 AM
http://www.sportseat...67v6no5tm5oi581
Anyone have or seen them fitted in a mini before?
Thanks.
Posted 01 June 2017 - 08:56 AM
Posted 02 June 2017 - 09:40 PM
Yes, I have fitted them to rally Minis.
You need to weld in a cross bracing made from steel angle, I use 2" x 2" x 1/4" thick and weld it to the inner sill and centre tunnel, with a support plate on the tunnel made from 2 mm thick steel sheet.
At the front you can make up an additional support to go across the existing cross member.
Once mounted the Mini is then a 2-seater as those seats don't have adjusters in order to comply with MSA/RAC regulations. You also must fit 3 or 4-point harnesses as diagonal belts don;t work with those seats. All motor-sport requires full harness belts.
Posted 03 June 2017 - 09:57 PM
Not strictly true, road going sprint/hill climb classes don't, 12 car rallies, autotest classes and various other club based events, the javelin sprint series doesn't.
Shooter
Posted 04 June 2017 - 04:46 PM
