Mpi Running Rough No Power Mystery!
Best Answer thelittlecarcompany , 13 January 2017 - 12:24 PM
Well after a lot of struggling it's finally off! It had very nearly destroyed the crank but after careful rebuild the mystery is solved it now runs perfect. Thanks for all your help guys :) Go to the full post
Posted 07 January 2017 - 10:18 PM
First of all I noticed the tappets were incorrectly adjusted, so reset them correct, after a compression test saw that all 4 were low, remembering that all exhaust valves were very tight I decided to whip the head off. Valves were a mess, real mess! in fact everything was!
Reseated valves - took a decade and a day! checked head, pistons slap and rebuilt, after a dropdown test compression very good.
Still wouldn't run right, put it on 3 different code readers we use in the workshop, one being oe rover gear from a closed down dealers and no codes present, checked everything on live data and lamda voltage is high and map Kpa is around 60 which is also high.
Every earth, sensor, wire etc have been checked/replaced and still no resolve.
On over run ( off throttle from hard revving unladen) it has a nasty rattle from timing chain end, removed belt to check it wasn't alternator or pump (which is what i thought initially so ignored it temporarily) and it's still there, I am assuming it is the chain or guide? Would this cause it to run awful if the chain had stretched? I've never had a fault like this before but is it possible it has a poor quality chain that has just stretched beyond normal thinking?
Thanks guys really stuck on this one!
Posted 08 January 2017 - 10:11 AM
Edited by minihobbymini, 08 January 2017 - 10:12 AM.
Posted 08 January 2017 - 12:42 PM
Since it shouldn't be making a racket it could have jumped a tooth as per minihobbymini or may sloppy on the timing.
These MPi motors run fairly close to the wind.
Please give more detail about what you mean by not running right at all.....
FS
Posted 08 January 2017 - 02:42 PM
So running,
It fires up without hesitation
it idles lumpy but doesn't cut out
It coughs pops and bangs when revved freely
Get in it and try to pull away and it has no torque at all even at wheel spinning revs
Sometimes it may be better than others but this may be down to road angles temperature etc
It generally drives like an earlier non injection mini that is miles out on the timing.
Thanks I will get into the chain and see what's going on and report back!
Posted 08 January 2017 - 04:32 PM
Posted 08 January 2017 - 08:26 PM
The MPi fuel injection will try it damndest to keep the motor running, if it were carb it would stall.
Cam sensor would have thrown a fault on the rover (presume testbook) system if fault.
Points very much to a mechanical issue which is being masked by the bomb proof ability of the injection cars to keep running
FS
Posted 08 January 2017 - 08:28 PM
For example is the exhaust and cat free passing?
Start with the basics as you have done mechanical settings and wiring, earths before thinking anything more complex
Good hunting and please update
FS
Posted 08 January 2017 - 11:26 PM
So hopefully this is the answer! The poor owner uses it as a daily car she is a full time carer so I have thrown most garage ethics out the window in order to fix this mystery for her!
Also to add to diagnosis, as well as the chain stretched and tensioner cracked, the crank chain pulley has for and aft play which will also throw the timing I guess, new pulley and woodruff key will also be fitted tomorrow.
Fingers crossed! Thanks for your help!!
Scott
The Little Car Company
Posted 08 January 2017 - 11:47 PM
FS
Posted 09 January 2017 - 06:48 PM
Posted 09 January 2017 - 08:33 PM
Posted 09 January 2017 - 09:04 PM
Posted 09 January 2017 - 09:51 PM
Posted 09 January 2017 - 09:52 PM
Posted 09 January 2017 - 10:00 PM
Has it got the locating rings in the inlet manifold?
