Help Advice Needed For Turbo Problem
Posted 08 January 2017 - 03:47 PM
Mini sits and idles fine and afr reads 13.9 - 14.6 and revs freely with no load. When trying to pull away mini bogs down and afr goes round to 18 or 19. Only way it will pull away is to rev it high and then it will be OK but then leans out after a very short time. I'm not sure where to look for the problem or what it could be.
Thanks in advance
Posted 08 January 2017 - 05:42 PM
Posted 08 January 2017 - 10:02 PM
Posted 09 January 2017 - 03:42 PM
Could be several things:
What needle have you fitted to the carb? I think the metro was BDD as standard, would be a good starting point with your spec.
How have you connected the part throttle lean off pipes and the other air and fuel connections on the side of the carb?
Have you set the idle fuel pressure to 3-4 psi?
Also check that your Megajolt spark map is sensible and use a timing light to check that the advance seen by the engine matches what the Megajolt is outputting.
Posted 09 January 2017 - 06:02 PM
Posted 09 January 2017 - 06:16 PM
