is it best to do before primer its been shot blasted thanks
Seam Sealer
Posted 11 January 2017 - 11:42 PM
Posted 11 January 2017 - 11:58 PM
Posted 12 January 2017 - 05:12 AM
If applying primer yourself (i.e. rattle can), I find it is best to put the seam sealer on first.
I have had instances in the past where applying it over primer has caused it to shrink and crack
Posted 12 January 2017 - 12:23 PM
Posted 12 January 2017 - 07:25 PM
im doing it with a spray gun should i etch it then seam seal not done much spraying on a road car done loads of race cars
Posted 13 January 2017 - 06:07 PM
One way is to brush lots of red-oxide primer into the seam then apply the seam sealer. Spray the desired primer over the surface once the seam sealer has dried out and finish with top coat.
Posted 14 January 2017 - 10:13 AM
thanks for the info going to do it this weekend
