Fixing Grille To Body
Best Answer GraemeC , 13 January 2017 - 06:06 PM
I assume that having been riveted on the original screw holes have been drilled out too large.
Short of welding them up and re-drilling, your options are:
  Grille buttons
  Rivnuts and machine screws (M3-M4 ish)
  Back to rivets
Go to the full post
18 replies to this topic
#16 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 19 January 2017 - 05:29 PM
i like the look of these from car builder solutions... http://www.carbuilde...nuts-pack-of-10
in thinking the rubber would stop vibration and help prevent corrosion ???
0022976_m6-rubber-rivnuts-pack-of-10_zps
Edited by THE ANORAK, 19 January 2017 - 05:43 PM.
#17 tiger99
tiger99
  • 8,584 posts
Posted 22 January 2017 - 03:03 AM
Good idea! At one time you could buy those in Woolworths as they had some domestic use. I am guessing that they may be found in Screwfix or even B&Q. And of course they do work rather well. I used them on a car once, but have forgotten which and what they were holding. I do remember that it was because I could not find the correct plastic bits. Possibly Mini headlights.
#18 BusheyTrader
BusheyTrader
  • 481 posts
  • Local Club: Nope
Posted 11 February 2017 - 11:43 PM
Maybe something like these flat nuts / spire nuts might help?
http://www.somerford...roducts_id=6165
They were used on many Triumphs over the years for interior trim and take a threaded or self tapping screw of a certain size. Originally meant to clip over the edge of a panel, the return part could be cut off and the nut kept in place behind the locating hole with a touch of PU sealer.
They're also cheap so no big loss if it doesn't work.
#19 paul748
paul748
  • Just Joined
  • 80 posts
Posted 12 February 2017 - 10:04 AM
These work quite well. I fitted some on a mini I used to have.
http://www.ebay.co.u...osAAOSwBLlVNPzH
Paul
