Wing Air Ducts
Posted 15 January 2017 - 07:52 AM
Posted 15 January 2017 - 09:13 AM
Edited by THE ANORAK, 15 January 2017 - 09:13 AM.
Posted 15 January 2017 - 10:18 AM
Posted 15 January 2017 - 11:48 AM
I don't know how anyone can use a Mini with zero incoming ventilation! Even minis with no face-vents, still had the big duct from the grill to the heater box to bring fresh air into the car (whether heated or not).
Posted 15 January 2017 - 12:38 PM
Posted 15 January 2017 - 12:52 PM
Posted 15 January 2017 - 01:06 PM
Early Mini's had a recirculatory heater which so called because it received air only from the cabin and did not have a duct supplying it with fresh air from outside the vehicle.
It was most commonly to be found on very early Minis, since it was gradually phased out from 1963 onwards. In theory, lowly 850 Saloons and some export 1000 saloons retained the recirculatory heater as standard fitment until the early 1970s (in reality, most customers asked for the optional fresh air heater instead), while Vans and Pick Ups persisted with it all the way through until the end of the 1970s.
"Often referred to as the 'fug-stirrer', the recirculatory heater would make already stale cabin air quite revolting after a prolonged drive, while its demisting abilities were non-existant (actually, it often made visibility worse)."
http://www.somerford...age=page&id=100
Posted 15 January 2017 - 01:34 PM
My 85 City "E" has no eye ball vents and doesn't have the ducting from the grill it's blanked off with a little plate
Posted 15 January 2017 - 01:40 PM
Posted 15 January 2017 - 02:04 PM
The early cars just had a recirculation heater with no fresh air at all.
Exactly my point ;)
Posted 15 January 2017 - 03:11 PM
Posted 15 January 2017 - 04:57 PM
Early Minis also had single leading shoe front drum brakes, it wouldn't justify me fitting them.
Given the Min's ability to leak and steam up I'd be grateful for all the ventilation on offer. Granted the heater ducting can be a source of some leaks.
Posted 15 January 2017 - 05:02 PM
And corrosion
Posted 15 January 2017 - 05:50 PM
