Electrical Fault
4 replies to this topic
#1 ashleyread1
ashleyread1
  • 200 posts
  • Local Club: London and Surrey MOC
Posted 15 January 2017 - 10:40 AM
HI,
so my wipers, indicators and heater have decided they dont want to work anymore, can someone point me in the direction of the wire that might cause this or even the fuse that has, checked all fuses i can see on the car including inline fuses but unable to find anything,
Everything else works
#2 Ethel
  • 25,416 posts
Posted 15 January 2017 - 05:08 PM
Wipers and indicators suggest an ignition fed live, the heater is usually run off "position 1" on the ignition key.
What year Mini? You could use some sort of circuit tester (meter or light) and a wiring diagram.
#3 Stu1961
Stu1961
  • 625 posts
  • Local Club: Still Looking
Posted 15 January 2017 - 05:17 PM
Hi ashley can you post the year car was made, I'm not a sparky but you will probably get a better response to you're query from those that know if you could give a little more info.
Have had a look at a wiring diagram for a post 76 car it would seem the heater switch and wipers share the same feed 5/6 in the fuse box, Light green with white tracer from the ign switch and light green and orange to the wiper and heater switchs check connections are making good contact (Wires to fuse box and fuse to fuse box contacts) If you have a multi-meter check for continuity across the in out terminals of the fuse box with the fuse in place, failing that with the ignition switch set to on check you have 12v at the input side Light green white tracer.
Like I said i'm not a sparky so don't take my post as gospel, I'm Sure someone will be along soon who can give you a better explanation than I.
Edited by Stu1961, 15 January 2017 - 05:40 PM.
#4 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 15 January 2017 - 06:50 PM
Assuming you have a four glass fusebox setup, all of those circuits are powered by the green/orange wires 3rd down on the right hand side of the fusebox, check the fuse and connections on either side of the fusebox.
As said above really (didn't see whole post due to using phone)
Edited by WiredbyWilson, 15 January 2017 - 06:52 PM.
#5 ashleyread1
ashleyread1
  • 200 posts
Posted 16 January 2017 - 09:27 AM
found the issue, wire had been cut slightly coming through the bulk head to the fuse box 5/6. thansk for all your help
