need to sort this out due to ill health don't want to sell her if i can make her a bit more comfy any idea what the cheepest option
Need Better Suspention
Posted 15 January 2017 - 11:33 AM
Posted 15 January 2017 - 11:37 AM
Posted 15 January 2017 - 11:52 AM
New rubbers and high profile tyres.
Posted 15 January 2017 - 12:17 PM
Posted 15 January 2017 - 01:04 PM
Yes this is what you maybe need:-
MSLMS0400 - Moulton Smootha Ride suspension kit.
An innovative design developed with the specific purpose to take the harshness out of the Mini suspension. This kit totally transforms all dry suspension Minis making a great car more comfortable and easier to drive!!
The special rubber suspension cones in this kit were designed by Dr Alex Moulton of Moulton Developments, who designed the original Mini dry suspension set up, and are manufactured by Avon VMS who made the original Mini cones. These are combined with specially modified Mini Sport Adjusta Ride units, negative camber and tracking rear brackets and a specially selected set of shock absorbers to create a whole new feel to the Minis ride.
This system is marketed exclusively world wide by Mini Sport.
The Smootha Ride kit includes:
- 2 x Moulton front suspension cones
- 2 x Moulton rear suspension cones
- 2 x Mini Sport fully adjustable front suspension units
- 2 x Mini Sport fully adjustable rear suspension units,
- 1 x Set of Mini Sport rear negative camber and tracking brackets
- 2 x Boge front shock absorbers
- 2 x Boge rear shock absorbers
- Comprehensive fitting and setting up instructions.
https://www.minispor...mini-sport.html
Or for 13" wheel Sportpack Mini's:-
https://www.minispor...heel-minis.html
Edited by mab01uk, 15 January 2017 - 01:27 PM.
Posted 15 January 2017 - 04:44 PM
We went a different path and had fitted springs from Minitastic along with good GAZ shocks. Absolutely brilliant. Still feels the same handling etc. We set the ride height a bit higher to give the springs some distance to work and played with the shocksettings. - thanks to CC Mini's for the help.
Minitastic do them in 3 different spring rates and we went for the middle one - fast road, because we have 13x7's on. If I was doing it again, I'd get the softer normal road ones.
Posted 15 January 2017 - 05:01 PM
looking at a spring set up want to get rid of the rubber set up only got 12inch wheels on don't know how old the suspention is i only replaced the front shocks due to mot fail
Edited by briancaveman2003, 25 January 2017 - 05:39 PM.
