Hif44 Spindle- Easy To Change?
Kt1966
, Jan 15 2017 05:47 PM
4 replies to this topic
Posted 15 January 2017 - 05:47 PM
I've managed to snap the spindle on my HIF44....(I know).
Looks like I can get a service/repair kit from Minispares but I'm wondering how easy/fiddly a job it is and any pointers on doing it?
Posted 15 January 2017 - 07:24 PM
The shaft itself is easy to change. Simply remove the linkages/springs etc from either end (making careful note of where everything goes) remove the butterfly and withdraw the shaft from the carb body. The bushes in the body are worth doing to, though you will need a suitably sized punch to enable you to press them out and the new ones in.
Phil.
Phil.
Edited by Turbo Phil, 15 January 2017 - 07:26 PM.
Posted 15 January 2017 - 09:21 PM
Thanks for that. The near side has just sheared off so everything should be ok there and the kit comes with the bushes by the looks of it.... Just really annoying though....
Posted 15 January 2017 - 09:31 PM
How the hell did you manage that?
It's easy enough, if you get stuck, bring the carb and spindle down to me and we'll sort it
Posted 15 January 2017 - 09:33 PM
An easy way of removing and fitting the spindles is searching for a screw with a flat head that got the right diameter.
A few nuts and a flat blade screwdriver and you'll easily get the bushes in and out :)
I used m4, M5 or m6 flathead screws for this, can't remember wich ones.
