Bowed Floor?
Posted 15 January 2017 - 11:27 PM
Does anyone know what will cause this? It's the same on both sides, I'll be replacing the plated excuses for sills anyway and the heelboard, the car technically still has 6 months mot left on it despite this
Just about visible in this pic:
Posted 15 January 2017 - 11:31 PM
Posted 15 January 2017 - 11:43 PM
Posted 16 January 2017 - 07:43 AM
past repair work only one way to deal with that and thats cut it out, and fit a large lump of floor :)
Posted 16 January 2017 - 04:57 PM
yes , agree with others , the size of that floor repair warrants a half floor , check out my playlist of my floor replacments , https://www.youtube.com/playlist?list=PL3DR9ASwHVgSU2XYURnVUGPvaCdFTfYA9
not professing to be expert by any means, but should give you some ideas.
Posted 16 January 2017 - 05:52 PM
Posted 16 January 2017 - 06:06 PM
It is a long unsupported panel.
Posted 16 January 2017 - 06:44 PM
Yes mine bows a little driver side mainly I've replaced inner sill and outer sill
As above mine is straight along the tunnel and sill
it is just basically a sheet of 0.9 mm steel so like any other panel it will flex
Mark
Posted 16 January 2017 - 07:34 PM
Having a poke through the heelboard hole looks like the inner sill isn't attached to the floor either so things will be a bit flimsy...
Posted 16 January 2017 - 09:52 PM
If the other side is that bad i would seriously consider going for a full floor including heelboard. Its a bit of a mess to say the least.
Posted 18 January 2017 - 11:25 PM
Surely very much less work too? No full length butt welds, just spot or plug around the edges and a little bit of seam in a few places. But good bracing is essential, although not difficult.
A full floor includes the inner sills and tunnel and those should prevent it bowing. Even more so if using one of the pre-assembled floors with outer sills too.
