Must I Change My Front Donuts?
Posted 18 January 2017 - 08:24 PM
Tia james
Posted 18 January 2017 - 08:29 PM
Posted 18 January 2017 - 09:14 PM
I'd hate to build the car up, to then have to change them.
Decisions decisions
Posted 18 January 2017 - 09:22 PM
Posted 18 January 2017 - 09:35 PM
Posted 18 January 2017 - 10:04 PM
Change them it's not the easiest job to do when the subframe is back on the car
Posted 18 January 2017 - 10:13 PM
Of course they will look fine, that's because they aren't compresses and have the full weight of the car and engine on them. The rubber cones have a usable life of around of around 10 years max. So if they are 36 year old originals, or even if they have been replaced unless fairly recently, they could still be nearing 15 to 20 years old. Also don't go for the cheaper non-genuine ones to save money, you will be buying genuine ones in a few months time after the cheap ones have collapsed and failed.
Posted 18 January 2017 - 10:29 PM
Its not just if they are too squished though, as the rubber hardens with age.
Posted 18 January 2017 - 11:43 PM
Exactly! And springing that is too hard is as bad for handling and roadholding that those that are too soft, as well as doing the occupants and the subframe, shell and suspension components no good at all.
The other things that should ALWAYS be changed when the suspension is apart are the knuckle joints, which are cheap, and result in rather expensive damage if they are allowed to wear out.
Posted 18 January 2017 - 11:49 PM
Posted 19 January 2017 - 05:47 PM
I think the pre-76 mini donuts may have been made originally with a stiffer rubber. Also early donuts are not as tall as the later ones, this changed some time in the 80's?
If you want a really firm ride try putting pre-76 donuts together with the original Hi-Los!
Posted 19 January 2017 - 05:57 PM
If you want a really firm ride, try 20 plus year old knackered donuts and hi-lows wound right down so the front top arms are on the bump stops.
Posted 21 January 2017 - 03:15 PM
Posted 21 January 2017 - 08:13 PM
Thanks james
