Idle Revs A Bit High..
6 replies to this topic
#1 maccers
maccers
  • 1,829 posts
  • Local Club: LSMOC
Posted 21 January 2017 - 10:39 AM
Have been running s/c 1293cc with custom fuel injection, ie not MPI stuff, using emerald ECU. Its been running 100% all ok for few years, but has developed a slightly high idle, 1500 to 2000 rpm, sometimes settling back to around 1100. It runs perfect apart from that.
Have not used it since around end November, started up almost first time, but then carried on running sweet the way it always does, but now just with a slight high idle. Oil pressure fine, coolant temp fine, everything just as it was but with this small issue now.
Any ideas?
#2 Steve220
Steve220
  • 4,896 posts
  • Local Club: BMC
Posted 21 January 2017 - 12:32 PM
What's the emerald base idle set at in your map?
#3 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 21 January 2017 - 12:47 PM
Air leak somewhere
#4 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 21 January 2017 - 10:26 PM
Air leak somewhere
 Check all rubber hoses and connections rubber is just not what it use to be these days
#5 Turbo Phil
Turbo Phil
  • 2,418 posts
Posted 22 January 2017 - 07:38 PM
Air leak somewhere
Exactly what my wife said when she found out she was pregnant.
Phil.
#6 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 22 January 2017 - 07:55 PM
lol thankfully the chinese dont make condoms
#7 ABZSupercooper
ABZSupercooper
  • 18 posts
Posted 13 September 2018 - 09:33 PM
could you post your emerald map base settings, I would like to check mine as I have an issue with rough idle / runing under 2000 revs
