Clubman Estate Shock Absorbers Question
Best Answer Spider , 23 January 2017 - 06:36 PM
Give them a call Cal, they do all sorts.
OK mate, I will do it now :)
For reference when talking to them, from the Centre of the Eye on the bottom, to between the Rubbers on the top, Extended length is 410 mm and Compressed length is 255 mm.
Just check with them how the measure them as I've sound some manufacturers work to mounting lengths and some to body lengths.
I would not recommend you go any shorter than 255 mm in the compressed length.
Go to the full post#1
Posted 22 January 2017 - 11:10 AM
I need a set of shocks for my clubman estate, I think I could use standard height front shocks but need the pickup rear, or do I just use standard all round???
Thanks guys
Posted 22 January 2017 - 12:24 PM
Unless they have longer bump stops on them.
Posted 22 January 2017 - 12:41 PM
Makes little difference other than than not letting the wheels droop as much.
Perfect mate, standard shocks it is then :)
Posted 22 January 2017 - 01:17 PM
what size wheels are you running?
Posted 22 January 2017 - 07:48 PM
10 inch wheels :)
Posted 22 January 2017 - 07:55 PM
Hello all, me again!!
Thanks guys
I wouldn't recommend standard length shockers in a Van / Estate / Pick-up or Moke.
The Trumpets are (or should be) longer. Fitting shorter saloon type shocks will allow the rubber cone to bottom out harder on the subframe, leading to broken trailing arm pins.
Posted 22 January 2017 - 08:33 PM
Thanks guys
So I need van shockers?
The van rear shockers are only available as an adjustable shock?
Edited by cal844, 22 January 2017 - 08:41 PM.
Posted 22 January 2017 - 10:33 PM
When I last looked a couple of years back, they were all I could find too.
Search around as there maybe something else around.
Posted 22 January 2017 - 10:46 PM
I shall try, will post back with findings :)
Posted 22 January 2017 - 11:47 PM
Even after raising the rear to higher than standard to lug things about, and then again after running the rear end decked out with quarter inch clearance between tyre and arch
Posted 23 January 2017 - 12:24 AM
Not in the UK I know, but available and might provide some leads
http://www.classicmo...roducts_id=1559
http://www.classicmo...roducts_id=1558
Posted 23 January 2017 - 06:40 AM
Give your sizes to Protech, I asked them ages ago, they said they'd make them up to whatever size you want.
Posted 23 January 2017 - 10:52 AM
Have just looked on their site, its only coilovers they build? All I need is a standard(non adjustable) set, I can buy standard front shocks no problem, but the estate/van rear shocks are only available in the UK as adjustable
Edited by cal844, 23 January 2017 - 11:15 AM.
Posted 23 January 2017 - 11:43 AM
I wonder if they're only adjustable to compensate for differing loads ?
Posted 23 January 2017 - 01:16 PM
