New Garage Floor And Dust!
Posted 22 January 2017 - 03:46 PM
Without going mad I was looking at floor covering. I bought some International Garage floor paint that I'll probably be taking back unopened....
Does anyone out there use any floor covering and what are they..?
Cheers!
Posted 22 January 2017 - 03:56 PM
Posted 22 January 2017 - 04:56 PM
Yup, PVA it. If your walls arent plastered etc either, brush some PVA/water mix into any exposed breeze blocks.
I painted mine with screwfix branded floor paint, its been fine for most things, but if i kick the jack sideways, the edges of the metal wheels peels it off dead easy. I guess most paint would suffer from that though.
Posted 22 January 2017 - 05:35 PM
Was thinking about getting these :
https://www.speedysh...CFSsz0wodAToBVA
Everything is covered in fine dust! Doing me head in :-(
Posted 22 January 2017 - 06:06 PM
No more dust!
Posted 22 January 2017 - 06:41 PM
We use Silka floor paint at work but this is probably overkill for a domestic garage and its pricey. (But I have seen people selling off the odd unopened barrel they they no longer need on eBay or Gumtree) There is a company called Zircon Flooring and they have some good info on epoxy or polyurethane floor paints if you're interested
Posted 22 January 2017 - 06:49 PM
Posted 22 January 2017 - 07:48 PM
If you're going to coat the floor with anything, you should leave it for a minimum of 4 weeks, preferably a little longer. I'm no concreter, but I think the concrete expels gas for some time after pouring. It's what our local concrete suppliers suggest.
Posted 22 January 2017 - 08:02 PM
Correct and it will need to be etched.
Posted 22 January 2017 - 09:46 PM
Posted 22 January 2017 - 09:49 PM
Give it a good chance to dry out, the deeper the concrete the longer you'll have to leave it.
Epoxy looks like a good job, haven seen it myself.
Buy some floorpaint and prime / size the floor with a diluted down coat first.
Posted 23 January 2017 - 01:33 AM
Second the curing time. I cast a new edge onto a slab. The slab's painted beautifully but the step eventually blistered a month or so later even though it had a few weeks before painting.
If you're going to paint blocks, brush on cement wash (just very runny mortar) as undercoat. You'll get a better finish and save paying for gallons of emulsion.
Posted 23 January 2017 - 09:41 AM
Those tiles look OK but for a garage will be expensive at £18/m2
At that price I'd be looking into Safety flooring on ebay - like a very heavy duty lino with 'grit' embedded in it to make it non slip.
Posted 23 January 2017 - 09:47 AM
Yep, got some exposed grey "Thermalite" blocks in there, was going to paint them white to enhance the light.
get a carcoon for now then. if the dust is too much.
or just wait a few weeks.
Posted 23 January 2017 - 12:03 PM
always just had bare concrete floor , and when screwfix grey floor paint.
did two coats (first coat took LOADS ) , yea might not be as hard wearing as epoxy stuff , but for the price really helps keeping it less dusty ,
i just get Air line and blow crap away / sweeping is easier as well.
might need to do fresh coat soon though , as just down a few months of welding over it ..
