Mini Mpi Cambridge
Posted 24 January 2017 - 10:52 PM
Is there anyone around Cambridge who has an MPI running well? Mine isn't and I would like to plug my diagnostic tools in it to get the "live" values of a healthy one.
Ben
Posted 25 January 2017 - 08:24 AM
I don't have a running MPI near you but I can give you the values you need
CTS in degrees C, should steadily increase from ambient temp up to 105 when the fan should kick in
ITS in degrees C, should be 20 to 50 on a hot engine, days like today its going to be at the lower end with the bonnet open
MAP sensor in kPA, should be 100 on key on and around 30 at idle, should increase as the throttle opens right up to 100 kPA (atmospheric pressure) with the throttle fully open
Lambda should been seen to fluctuate rapidly from high to low, 0.2 - 0.8mv
TPS expect 4.5 upwards
Throttle switch is either on or off
the signal from the cam and crank sensors are reference only, normally say OK on the SP kit
Hope this helps.
What problems are you experiencing?
Posted 25 January 2017 - 11:43 AM
FS
Posted 25 January 2017 - 01:56 PM
Thanks for figures Ivan but I have a snap on ethos and vacuum values are in mhg.
