Alarm/central Locking Fail
1 reply to this topic
#1 kelsmartyn
kelsmartyn
    Starting My Mini Up
  • 1 posts
Posted 25 January 2017 - 04:25 PM
Good Afternoon! :D
Last night, I did a rear wiper delete & forgot to re-connect the cable that powers the number plate lamps and boot-open switch in the handle. I checked all the fuses before realising what I had done - then managed to re-connect the wire so that the boot would open/close again. However, my central locking now isn't working since this happened. My remote key doesn't work anyway(acrylic nails :shy: ), but i can't manually lock both doors simultaneously anymore. It also won't lock my boot & fuel cap cover. ..Also, the alarm isn't setting :mmkay:
I've checked the fuses for the central locking & alarm - both are fine.
The centre console toggle will allow me to unlock both doors, but not lock them. The only way to lock my passenger door is to push down the button on the inside of the door.
HAAAALP!! :ohno:
#2 nicklouse
  • 17,945 posts
Posted 25 January 2017 - 04:31 PM
sounds like you have a MINI not a Classic Mini (as advised when you signed up) you will do better joining Mini2 or toatalmini
even though a few members have MINI on here you will get a better response on the above forums.
