Gutted - New Doors?
15 replies to this topic
#1 Lennyliverpool
Lennyliverpool
  • 329 posts
  • Local Club: northampton
Posted 30 January 2017 - 06:35 PM
well just over 2 years after a full resto/paint stc (and £4k) I have just noticed the drivers door bottom has started to come away from the skin - there has obviously been water ingress over time and as the company didn't put the drains holes under the door back ,which I never noticed till recently,it has caused this problem.....
So - I will obviously be on the phone in the morning but in the meantime is it better/cheaper to replace the doors completely or get the bottoms cut away and replaced?
The rest of the car looks very good still so I am hoping its "one of those things"
The car is used daily so need this doing quick as well as properly
Any suggestions?
Lenny
#2 Daz1968
Daz1968
  • 2,058 posts
Posted 30 January 2017 - 06:39 PM
As car is used daily, I would purchase another used door and repair and reskin that, paint the inside of it, then fit and have outside painted including blending into adjacent panels.
Maybe if you are paying someone else to repair the doors it may be cheaper to purchase new.
Edited by Daz1968, 30 January 2017 - 06:39 PM.
#3 1984mini25
1984mini25
  • 8,781 posts
Posted 30 January 2017 - 06:52 PM
Best off drilling some holes (standard doors have 3) to let the water out that finds its way past the door window weather strips. Replace if they are old or have gaps between them and the glass. Then have your current doors if they are the original and fit ok (no two minis doors are ever the same) repaired and re-skinned.
Edited by 1984mini25, 30 January 2017 - 06:52 PM.
#4 sledgehammer
sledgehammer
  • 3,060 posts
Posted 30 January 2017 - 07:01 PM
after re-skinning / painting , flood the area with waxoil
I usually block the drains & spray inside the skin , to get the waxoil into the skin joint
It may pay to warm the door when doing this , as the waxoil creeps into any voids easier
after it has dried / cured , remove bungs from drains & make sure they are clear
have heard of extra drains in the doors as well , for added ventilation
#5 Rocket.
Rocket.
  • 1,441 posts
Posted 30 January 2017 - 07:04 PM
I'd personally say re-skin the doors you have as mentioned above no two mini doors are the same and a lot of them take extra work to get the gaps right so if you're paying someone else to do that it's going to cost more money
Plus you'll know what you're starting with
#6 Lennyliverpool
Lennyliverpool
  • 329 posts
Posted 30 January 2017 - 07:17 PM
Thanks all seems like a resin job as the doors themselves are ok
What do you think cost would be roughly for the work?
Re skin and paint both doors?
I will check tomorrow but some idea would be appreciated
Lenny
#7 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 30 January 2017 - 07:24 PM
I think the traders ask upwards of £150 for a re-skin - then you have prep and paint.
In reality it takes about 2 to 3 hours to re-skin a door ... so the cost above seem reasonable.
Maybe do a Google and you will find at least two companies offering the service, I know 100% one of them will not paint the door ... not 100% sure about the other one.
#8 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 30 January 2017 - 07:48 PM
i see your in Northampton... what company did the work ???
if their initials are MB i would expect a load more problems !!!
#9 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 30 January 2017 - 08:11 PM
4k a new door is best part of 500quid
#10 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 30 January 2017 - 08:17 PM
I'd buy another door, offer it up and reskin it over a weekend,
then put the current door back on,
then sort the gaps another weekend (weld filler rods, etc)
put original door back on,
prep / paint new door (DIY or outsource),
swap the new door in. Might take a while but it would be worth it, and not too costly?
#11 Lennyliverpool
Lennyliverpool
  • 329 posts
Posted 30 January 2017 - 08:18 PM
No the company were not "MB"🙄
The company I used are Towcester way
Emailed him and he has requested pictures...so we will see
#12 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,128 posts
  • Name: Sean
Posted 30 January 2017 - 08:25 PM
Swapping doors usually ends up as a bag of nightmares.  You're better off using your existing doors
#13 1984mini25
1984mini25
  • 8,781 posts
Posted 30 January 2017 - 08:56 PM
All well and good proving the hinge nuts don't snap on removable or from repeated tightening. And that you can get the pozi or star bolts lose to remove the hinges from the old door.
#14 DomCr250
DomCr250
  • 667 posts
Posted 31 January 2017 - 02:07 PM
You can fix the hinge bolts with new studs once the door is off. If it's going to be reskinned the poxi nuts will come loose with a good application of Wd overnight and a blow torch to free them off.. It's easy to do from inside the door after the skins come off.
Edited by DomCr250, 31 January 2017 - 02:07 PM.
#15 Lennyliverpool
Lennyliverpool
  • 329 posts
Posted 31 January 2017 - 03:49 PM
1st quote £450 to redo bottoms of both doors & skins with paint etc and this time with drainage holes
2nd quote new doors with paint £800...
