Could anyone recommend a cavity wax i'm thinking of ordering some Bilt Hamber dynax s50 has anyone used it?
I'm also looking for a set of new shocks originally it had non-adjustable konis but I cant seem to find them anywhere does anyone know an equivalent?
I used the S50 in cavaties and really liked it. Much cleaner, easy to use and certainly travels well. I found it a lot cleaner than Waxoil. I had warmed it up a good bit first too and was expecting a fair bit of overspray mist but it was fine.
We had done the inside of the doors too and when I had to do a bit of work in there 6 months later, everything was well coatedand a touch unpleasant to work in, just what you want from a cavity wax.
I’ve seen the other oderbody version used, just the clear not the black tinted and it seemed to be similarly good to apply. A wee thin coat was barely visible a and a thicker one had a slight yellow tint. Just a good bit more expensive than waxoil.
Dear knows if it’s any better, I’ve only had it in for 2 years and it’s all good. I’d certainly use it again for the cavities. I’d use the other version for the underside except that it would be a bit expensive, our Mini is built for enjoying on the road so I’ve a good coating on her.
