Rear Subframe Type?
suspension
6 replies to this topic
#1 charlieheal123
charlieheal123
  • 31 posts
Posted 07 February 2017 - 05:19 PM
Hi Guys,
I have been advised from a fellow mini enthusiast that it may be time to replace my rear subframe due to it being heavily rusted in the key stress points.
I've seen on Mini Sport that there are two types of rear subframe that could be for my car, which is a 1991 Cooper, as one rear subframe is listed as a 'pre 1991', and the other as a '1991 on' which has exhaust hangers.
Anyone know which one fits my car??
Many Thanks
Charlie Heal
#2 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 07 February 2017 - 05:32 PM
a 91 cooper could be either a carb car or fuel injection, its right on the change point.
thats what the change in subframe is about as the fuel injection cars had different exhaust hangers
if its carb its pre 91 if its injection its 91on
once again mini sport is not very clear on this.
#3 Steve220
Steve220
  • 4,887 posts
  • Local Club: BMC
Posted 07 February 2017 - 05:56 PM
Don't buy it from minisport, they're useless. Minispares will be your better option.
#4 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 07 February 2017 - 06:41 PM
Looking at your profile your car is the carb version. So you want the pre 1991 frame :-)
#5 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 07 February 2017 - 06:43 PM
+1
#6 Northernpower
Northernpower
    Mr. 7-Port
  • 2,409 posts
  • Name: Graham
Posted 07 February 2017 - 06:55 PM
+2
#7 Cooperman
  • 23,039 posts
Posted 07 February 2017 - 07:15 PM
Geometrically the sub-frames are all identical. The only differences are with the hydrolastic ones which is not an issue for you, and the later ones which had the les-good exhaust hangers.
You can use any of the frames and it is best to use the earlier type of exhaust mountings which have the big 'choc-block' bolted to the front cross member of the rear frame plus a pair of 'cotton-reel' rear mountings.
I always make up the necessary clamps and plates to mount using these mountings and the exhaust is then well-fitted and won't 'fall off'.
As above, buy from Mini Spares.
Also tagged with one or more of these keywords: suspension
