And want to keep a build log on thuis forum for the people that are intrested
Møre pictures will follow
Edited by 998cc, 08 February 2017 - 09:19 PM.
Posted 08 February 2017 - 09:15 PM
Posted 12 February 2017 - 10:33 AM
here some old pictures from the build of the intake manifold my welding skills are not the best
IMG_2753.JPG 33.32K 8 downloads
IMG_2846.JPG 45.71K 8 downloads
IMG_2921.JPG 57.53K 10 downloads
IMG_2922.JPG 59.02K 8 downloads
IMG_2923.JPG 56.02K 6 downloads
IMG_2937.JPG 74.41K 12 downloads
Posted 12 February 2017 - 11:10 AM
here some trail fitting with the charger on it
IMG_2954.JPG 75.82K 16 downloads
IMG_2939.JPG 59.96K 8 downloads
this was the plan for the pulley for the charger but with some calculations it turns out it wil run 19 psi of boost and
that wil not last. i found this on a forum
IMG_3217.JPG 32.03K 8 downloads
IMG_3218.JPG 33.76K 3 downloads
IMG_3219.JPG 30.82K 3 downloads
and this is a 80 mm pulley with a final ratio of 10 psi, a lot better.
so i let something like that made by a friend with machining skills
Posted 12 February 2017 - 05:39 PM
today i bolted the head back on with the decompression plate
de plate is 3cc
IMG_2830.JPG 56.04K 6 downloads
IMG_3580.JPG 68.96K 6 downloads
the original breather on the back of the engine is in the in way of the supercharger belt.
so i modified it, so it wil fit to the other side.
IMG_3582.JPG 75.24K 3 downloads
the rest of the engine wil be painted too.
the yellow is a bit to yellow by my opinion but i wil leave it like that
im now waiting for the crank pulley and then the engine can be back in the car
Edited by 998cc, 12 February 2017 - 05:42 PM.
Posted 21 January 2018 - 09:56 AM
the new pulley
IMG_3681.JPG 20.7K 1 downloads
IMG_3682.JPG 21.53K 0 downloads
IMG_3690.JPG 28.14K 2 downloads
IMG_3691.JPG 44.96K 0 downloads
is is bolted to the original pulley
made out of allu and i'm very happy with the result
Posted 21 January 2018 - 10:04 AM
after i had made the supercharger inlet manifold i was not happy with the result (terrible welding)
so a friend of me is a welder a nd made one of stainless steel
Posted 21 January 2018 - 10:20 AM
here the pulley on the engine
IMG_3818.JPG 67.15K 1 downloads
IMG_3819.JPG 61.84K 0 downloads
for the carb inlet pipe i fitted a adapter plate for better fitting on the supercharger
IMG_4173.JPG 24.32K 1 downloads
IMG_4175.JPG 55.46K 2 downloads
so engine back in the mini for trail fitting
IMG_4268.JPG 49.71K 3 downloads
the supercharger pulley was too close to the clutch cylinder
so i searched for a aftermarked cylinder that is smaller and do the job right
Posted 21 January 2018 - 01:07 PM
Think you saved yourself a lot of heart ache getting the manifold remade. Bet the first first one leaked a little.after i had made the supercharger inlet manifold i was not happy with the result (terrible welding)
Posted 22 January 2018 - 07:50 PM
yes it leaked a lot, next thing on the to do list is
copper pipe around the intake so the intake won't get to cold
Posted 22 January 2018 - 07:55 PM
Awesome thread, going to follow this one as i'll have a spare 998 soon!
Posted 22 January 2018 - 08:27 PM
looking good, what carb are you fitting?
Posted 23 January 2018 - 07:33 PM
it runs al ready on a hiff44 carb needle bdd turbo needle
but it's not running perfect, i think because of the carb gets to cold
so after i have fixed that problem (copper pipe around the intake pipe on the coolant circulation)
it will run a lot better i hope
Posted 24 January 2018 - 11:04 AM
Nice Build!!!
any specifications on the engine? Standard pistons? - where did you get the decompression plate?
I am looking into a turbocharging a 998A+ draw through (or suck through) turbocharger
Posted 24 January 2018 - 08:32 PM
Cool build plan and cool looking Mini. Best of luck with it :)
Posted 25 January 2018 - 03:21 PM
I'd ditch that idea if I were you and put a small weber on instead. The old wrapping the long inlet pipe with small bore copper isn't really addressing the problem
