70hp for a 998 will make it peppy, it that at the wheels?
No 49 at the wheels
Next step
-electric fuel pump
-big chamber and ported head
-Nice cam
I want 80 hp then i’m happy
Posted 09 June 2018 - 03:26 PM
Posted 10 June 2018 - 12:24 PM
Posted 10 June 2018 - 12:50 PM
Posted 25 June 2018 - 11:03 PM
Hi, great build, I hope you don't mind me asking but (and it has probably been asked before.) would it be possible to get dimensions of your inlet manifold?
I have slowly been collecting parts to do a similar build, I have the supercharger and have decided on a Weber 40 carb, flanges, tensioners, belts etc, just not sure where to start with the manifold build to make sure everything lines up correctly!
Posted 27 June 2018 - 06:47 PM
I'd say you will need to have 2x 40mm for a weber. One for each sideHi, great build, I hope you don't mind me asking but (and it has probably been asked before.) would it be possible to get dimensions of your inlet manifold?
Posted 27 June 2018 - 08:20 PM
thanx, ofcourse i dont mind the charger is of at the moment for fitting the boost gauge. i wil measure it and wil post it.
did you have a brake booster? im wondering were you can find the space then.
Posted 27 June 2018 - 09:40 PM
Thanks for the reply, yes I do have a brake servo / booster, but I believe if you machine the inlet on the charger and weld a flange to it, you can just about fit the carb directly to the charger. One of the better know kits is set up this way.
Posted 27 June 2018 - 09:43 PM
I have slowly been collecting parts to do a similar build, I have the supercharger and have decided on a Weber 40 carb, flanges, tensioners, belts etc, just not sure here to start with the manifold build to make sure everything lines up correctly!
Thanks HUBBA.HUBBA I may not have been clear, but I was talking about the charger to head inlet manifold
Posted 28 June 2018 - 12:56 AM
Like this....Thanks for the reply, yes I do have a brake servo / booster, but I believe if you machine the inlet on the charger and weld a flange to it, you can just about fit the carb directly to the charger. One of the better know kits is set up this way.thanx, ofcourse i dont mind the charger is of at the moment for fitting the boost gauge. i wil measure it and wil post it.Hi, great build, I hope you don't mind me asking but (and it has probably been asked before.) would it be possible to get dimensions of your inlet manifold?
Posted 28 June 2018 - 07:38 AM
Fyi I have vmax one I would sell. So all the dimensions are correct and it has a boost pipe take off. Pm me if interestedThanks HUBBA.HUBBA I may not have been clear, but I was talking about the charger to head inlet manifoldI'd say you will need to have 2x 40mm for a weber. One for each sideHi, great build, I hope you don't mind me asking but (and it has probably been asked before.) would it be possible to get dimensions of your inlet manifold?
Edited by HUBBA.HUBBA, 28 June 2018 - 07:40 AM.
Posted 28 June 2018 - 09:08 AM
Like this....
Yes, that would be the one!
Posted 30 June 2018 - 05:38 PM
Posted 01 July 2018 - 08:13 AM
IMG_2754.JPG 49.52K 2 downloads
this is what i used
