Hi all, just got most of a car I bought in boxes put back together. Started it today and ran Ok, then started to mess about. Couple of things, where does the red pipe go which is fastened to the air box? One of the pipes fron a unit on the bulkhead behind injection goes to the ecu. Where does the other one go? Till I get these sorted probably won't run right anyway. The multi bung on the stepper motor is dirty with being stood around for years, any magic fluid available to clean these? Think this is probably causing the funny idle and stalling of engine from idle. Hope help is at hand to sort it as although I'm a carb man at heart, would rather leave the car standard. Cheers.
Mini In Boxes
Wert
, Feb 10 2017 09:32 PM
1 reply to this topic
