Spi Camshaft Compatibility
9 replies to this topic
#1 RooBoonix
RooBoonix
  • 1,224 posts
Posted 11 February 2017 - 01:59 PM
Hi,
I've currently got my 1994 1275 SPi engine in bits, out of my Cooper.
I've been doing some research into camshafts and I may fit a better one if funds allow.. current one is in good condition. But, what I can't seem to find out is if the SPi engine requires a special injection cam or if it can use any 1275 compatible cam? I understand the MPi used a cam sensor lobe, but the SPi doesn't have this so does it really matter..?
I'm not looking for anything spectacular, if anything I'd just want a mild road cam.
Cheers,
Cam.
#2 mina08
mina08
  • 255 posts
Posted 12 February 2017 - 06:40 AM
From what i have learnt is that the kent cam 274 is the one that works with the SPI.
I will be fitting one to my engine soon.
#3 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 12 February 2017 - 06:58 AM
sw5i or speak to ac dodd
#4 RooBoonix
RooBoonix
  • 1,224 posts
Posted 12 February 2017 - 10:06 AM
Sweet, well if 2 others think only the injection cam's work then I can't be far off.
#5 ACDodd
ACDodd
  • Mini Docs
  • 2,657 posts
Posted 14 February 2017 - 12:59 PM
My own ACD-RS cam works in the SPI.
The Stock A+ 1275 cam is the same as the spi cooper cam and can be used as a direct replacement.
Ac
#6 RooBoonix
RooBoonix
  • 1,224 posts
Posted 14 February 2017 - 01:07 PM
Ac
I was looking at your RS cam as a possibility.. will have a think!
#7 psmini
psmini
  • 286 posts
  • Local Club: None
Posted 14 February 2017 - 01:21 PM
My 1293 spi has a stage 4 head and a 274 cam, really impressed with the performance.
#8 idlethumbs
idlethumbs
  • 272 posts
Posted 16 February 2017 - 10:19 PM
Mine is currently being built with the piper 270i which is injection specific.
I was advised the ecu restrictions on power of the spi means whilst other cams will work fine, the potential is limited by the fuelling restrictions so you need the power bands in a more specific place to make the most of them.
#9 RooBoonix
RooBoonix
  • 1,224 posts
Posted 17 February 2017 - 01:18 PM
Got it. Will ensure I get an injection cam, if any
#10 brivinci
brivinci
  • 1,103 posts
Posted 20 February 2017 - 08:18 PM
Calver recommended the Piper BP255. I had the Swiftune SW5-07 in there before but needed replacement. The Piper has a very similar profile to the SW but its better built as it has an oil alley way through the middle and into lopes. You dont get that on most other cams, especially for the price.
