Stupid Questions Time, Mig Gas Related.
Posted 12 February 2017 - 04:21 PM
Second question, after reading suggestions that around 10lpm is about right for mig welding with the 5% stuff I've been doing that, should I set it to around 10 on my gauge or have it as I have now where I'm showing 10 when it's flowing, am I wasting gas do you think?
I've just switched from 0.6 to 0.8 wire and tip and I'm happier with that, should I just reduce the gas until I feel it's not welding well? What's the first sign of gas starvation?
Thanks, Pete.
Posted 12 February 2017 - 04:47 PM
Yes less than half left, should still run for a little while but needs changing very soon. 200 psi to start with is rubbish, are you sure it's not Bar??
My bottle from BOC although considerably larger comes with 3000 psi as standard.
Posted 12 February 2017 - 04:49 PM
Posted 12 February 2017 - 06:02 PM
I've probably got it too high then, what lpm would you suggest and do you set it when flowing or stationary? Stationary seams obvious but I'm a noobie.
Posted 12 February 2017 - 06:18 PM
Posted 12 February 2017 - 07:08 PM
Providing you have the regulator set correctly then yes. The flow is minimal. If you have a howling gale emanating from the shroud as i already mentioned then you will use it very quickly and pointlessly.
Posted 12 February 2017 - 07:34 PM
What sign should I look for to show the gas is too low?
Posted 12 February 2017 - 08:26 PM
Thanks I'll see how it goes maybe the second half of the bottle week last a lot longer now!
Poor welds, porous welds will be the biggest indicator.
Posted 12 February 2017 - 08:34 PM
Thanks I'll see how I get on tomorrow night now then.
Posted 12 February 2017 - 09:56 PM
10 lpm is what I set to but I use a flow meter after the gauge as they are inexpensive and easy to read and set up.
Posted 13 February 2017 - 02:17 PM
Posted 14 February 2017 - 01:25 PM
Not very scientific, I know, but short of destructive testing of a sample of welds (which you should do anyway from time to time) there is no other obvious DIY method of assessing adequacy of gas flow.
I would suggest running a few short welds on clean offcuts of 0.9mm steel with the flow set at various levels from 0 to 10 lpm and see how the welds vary. If in doubt, post some photos here. Also, ask at the MIG welding forum if in doubt.
Posted 21 February 2017 - 05:25 PM
Posted 24 February 2017 - 06:26 PM
I have got a new bottle and it was indeed 2000psi so that's all good, I have solved my issue of worrying about it running out by smashing the regulator after the bottle fell over......time to make a bracket to hold it to the wall as I planned all along, lol. the flow meter survived though so I am not replacing it.
