Spi Circuit Car Build Questions
Posted 15 February 2017 - 09:03 PM
Also, what's the best route for the battery, brake and fuel lines if run inside the car? I was looking at running them down the L/H side of the centre tunnel, bearing mind that there's 3 fuel lines.
Thanks for help.
Adam
Posted 15 February 2017 - 10:29 PM
Not sure about the passenger seat, but you wouldn't need to refit the inertia reel belts - not many rally cars have them!
Our brake lines run down the LH side of the tunnel, the fuel line along the passenger side inner sill, battery cable along the drivers side inner sill.
Keith
Edited by keefr22, 15 February 2017 - 10:31 PM.
Posted 15 February 2017 - 11:06 PM
I run my brake and fuel lines down the LH side of the central tunnel and the battery line down the RH side of the tunnel.
The FIA master switch I fit on the LH side of the driver's seat.
That way, the fuel and battery lines are separate and the master switch is easy for the driver (or navigator in the case of a rally car) to reach in the event of a crash.
Posted 19 February 2017 - 10:37 AM
Adam
