Underneath Paint Finish?
Posted 18 February 2017 - 07:50 PM
Thanks folks.
Posted 18 February 2017 - 08:58 PM
Personally i would stonechip then topcoat.
Posted 18 February 2017 - 09:32 PM
Posted 18 February 2017 - 10:02 PM
I use this at work and it's very good
http://www.etalon.gr...erbody-coating/
Can be overpainted and gives a very nice finish
Posted 18 February 2017 - 10:03 PM
Posted 18 February 2017 - 10:06 PM
That looks ideal, I will be using cans rather than a gun too which they do.
Posted 18 February 2017 - 10:26 PM
Posted 19 February 2017 - 01:31 PM
Posted 19 February 2017 - 01:38 PM
I will say that it is so much easier with a shultz gun and compressor though and cost effective if your going to use rattlers the same gear is very good for waxing later too so I would give I some serious consideration.
Edited by dyshipfakta, 19 February 2017 - 01:40 PM.
Posted 19 February 2017 - 05:42 PM
Posted 19 February 2017 - 05:49 PM
Posted 19 February 2017 - 07:03 PM
Just blow some white spirit though is all I did as it's all I had at the time worked fine.
When you do this not only suck through some white spirit but then place your finger over the nozzle after and this will then back blow through the siphon tube.
You will get a much better finish using a proper schultz spray gun plus you if you want to add a little white spirit to thin it down. The biggest tip though is to thoroughly shake the tin after you have immersed it in hot water for ten minutes.
Posted 19 February 2017 - 07:33 PM
I'll grab a shultz gun then, you lot have convinced me.
Posted 19 February 2017 - 09:27 PM
