Rust?
Posted 20 February 2017 - 08:02 AM
School me so I don't end up with a potential rust bucket.
Posted 20 February 2017 - 08:13 AM
Posted 20 February 2017 - 08:26 AM
Posted 20 February 2017 - 08:42 AM
Posted 20 February 2017 - 09:17 AM
If you look at rebuild threads on this forum, you'll be able to see the areas that can be badly effected by the dreaded tin worm, Ben_O's Mill Road Garage threads in particular are excellent, lots of photo's & relevant information.
When you actually go to look at a car, don't fall into the trap of thinking it looks lovely, have the attitude of "how bad is it really", make sure you really inspect everything, lift the carpets, check the boot floor, get it up on ramps to check underneath etc. etc.
Posted 20 February 2017 - 10:10 AM
From the waist down.
And don't forget, it might look OK until you start working on it and pulling things apart and finding rust everywhere.
Posted 20 February 2017 - 10:42 AM
And the waist up sometimes, lol
Posted 20 February 2017 - 02:06 PM
Basically, where there is metal, there might be rust lurking away
Posted 20 February 2017 - 03:20 PM
Headlamp appertures on wing
Wing to front panel joint
Front of bonnet
Scuttle
Gutters
A panel
Bottom of doors and boot
Inner wing, particularly at the bottom and behind damper mounts where you can't see
Floors, particularly front
Toeboard
Sills (inner and outer)
Doorsteps
Lower part of quarter panel
Rear inner wheel arches
Heelboard
Boot floor, particularly to the rear in the corners
Bottom of rear panel (just below hinge line of boot)
And probably other areas I've forgotten!
Edited by Swift_General, 20 February 2017 - 03:21 PM.
Posted 20 February 2017 - 04:27 PM
Posted 20 February 2017 - 11:12 PM
Inside out unfortunately, making it very easy to cover.
Posted 20 February 2017 - 11:27 PM
