Does anyone know the total rack travel (lock to lock) for a sportspack rack (2.7 turns) and a normal rack (2.7 turns), millimeters preferably?? Thanks in advance....
Rack Travel
Posted 20 February 2017 - 04:39 PM
Posted 20 February 2017 - 04:53 PM
I can give you the width of the spacers that are fitted to a standard rack to bring it to sportspack spec if that helps.
Posted 20 February 2017 - 04:58 PM
That'll help, I can measure my sportspack later on and work it out....cheers
Posted 20 February 2017 - 05:00 PM
Surely the sportspack doesn't have 2.7 turns as (with the spacers in) it hits the stops 'early'
Posted 20 February 2017 - 09:19 PM
Just measured the sportspack and for anyone that's interested it's 80mm lock to lock.
Graeme I guess you are right, going on your theory it couldn't be 2.7 if the spacers cause a restriction. I think the point I was trying to make was that it wasnt a quick rack.
Edited by cptkirk, 21 February 2017 - 08:34 AM.
Posted 21 February 2017 - 08:39 AM
Any pics of these spacers in place on a rack ?
I have a standard rack and plan to go sportspack.
Yhanks
Posted 21 February 2017 - 09:20 AM
Yhanks
10th photo down
http://www.theminifo...l-uk-type-mkii/
Posted 21 February 2017 - 10:25 AM
Thanks,
Can they be added without removing the balljoints ? weld in two half moon parts ?
Posted 21 February 2017 - 11:04 AM
the after marked KAD ones just pop on.
Posted 21 February 2017 - 11:45 AM
Thanks,
https://www.minispor...imiter-kit.html
Posted 21 February 2017 - 11:46 AM
Nick, did you manage to get a size for the spacers?? They look approx 8-10mm??
Posted 21 February 2017 - 11:55 AM
not yet, but at a guess 1/2" need to find the ones I did not fit. and they might be in the other garage. will be on the hunt after work.
Posted 21 February 2017 - 10:45 PM
Posted 22 February 2017 - 06:44 AM
Thanks,
Yes. They did that in our local factory from the Mid 80's on for the UK racks that were fitted to our big wheel (13") Mokes. The spacers were 8.0 to 8.4 mm thick, made from round mild steel stock, then cut in half and tacked in place. Be very careful not to get too much heat in to the joint on the rack as it does have a hardened outer cup and the seat is nylon.
Posted 22 February 2017 - 12:57 PM
Some people use a medium strength plastic like Delrin. The load applied when in action is compressive. I have seen the plastic variety with screws on other vehicles.
Many ways to skin a cat. They all work.
