Hi as the title says, I've finished painting the inside of my car and I'm about fit the grommets and other parts such as seat brackets etc, I'm wondering if I rely on the fit of the grommet, or do I aid it with something like silicone sealant. Any advice greatly recieved
Tia Jim
Fitting Grommets
Jimbob98
, Feb 20 2017 08:10 PM
6 replies to this topic
Posted 20 February 2017 - 08:10 PM
Posted 21 February 2017 - 08:28 AM
I plan on using a liquid rubber sealer on mine
Posted 21 February 2017 - 09:57 AM
I just used loads of waxoyl type stuff in mine
Posted 21 February 2017 - 11:56 AM
I use silicon grease to ease them in and help with a seal.
Posted 21 February 2017 - 12:40 PM
I don't like silicone anywhere in case the area needs painting again in the future. Traces of silicone make that problematic.
Rubber or mastic type sealants are fine. I use them around the grommet, ie in the groove, and inside eg to fill the spaces between wires in a bundle.
Oh, and if painting the area around the hole during a restoration, I use a brush around holes to get a thick build up of zinc primer, followed by whatever paint system you use. Same if drilling a hole in a modern car, as the hole tends to be a place where rust will start. The suggestion above of using Waxoyl is also very good.
Edited by tiger99, 21 February 2017 - 12:51 PM.
Posted 21 February 2017 - 05:26 PM
Excellent, thanks for the replies, I've painted the floor both underneath and inside so it well sealed at its edges so any of the sugestions would be good. It seems that all of the options involve using something to aid in sealing, and not relying on the grommet alone.
Thanks jim
Thanks jim
Posted 21 February 2017 - 05:33 PM
I'd just stick the grommet it no need for sealant it's not a boat..
