Recent mini build back on the road Sprite 1994 1275. Everything is good passed its MOT no advisories. However driving home brimmed the tank and it was only reading half. It had a new sender so I followed the guide on here to add the voltage regulator on the back of the pcb.
Success! The guage reads the fuel right. However I now notice while driving the engine temp guage is running in the red!
So earlier I let the engine idle with the rad cap off heater valve open to see if it bubbled up. It got up to temp and back in the red no bubbles except when I turned it off it did a little bit. Squeezed all the hoses and they seem fine. Both pipes to the matrix were hot. I also took the temp of the coolant in the top of the rad immediately after switching off and it was reading 72C. The rad electric fan didn't come on that comes on at 92 off at 88 and my thermostat is 88 degree too.
Could I have a dodgy sender? Is my engine overheating? Have I done something wrong with the voltage regulator? Am I missing something?
Look forward to your suggestions and help
Edited by systemcp, 21 February 2017 - 07:40 PM.
