Thermostat Housing Gunk
Posted 21 February 2017 - 08:35 PM
Posted 21 February 2017 - 09:00 PM
It is aluminium oxide caused galvanic corrosion. Basically the different metals, iron, steel, and brass (in this case) are reactive with each other in the presence of an electrolyte. The electrolyte is commonly water with the presence of salts. The salts can come from the air, but in the case of a car during winter, it comes from the road. The fact that you have a ground strap connected to the thermostat housing probably isn't helping much either as electrical current is flowing through this localised area.
Unfortunately, in the main galvanic corrosion will always occur, especially in winter, but removing that ground strap (connect it somewhere else) might help. Regularly washing down these parts with clean water will also help.
Posted 21 February 2017 - 09:01 PM
Posted 22 February 2017 - 09:16 AM
Try some bi-carb of soda mix .. works on battery acid "fluff" .. might help. Otherwise elbow grease ...
Odd place to fit an earth strap? Thought they went on the gearbox end?
Edited by gazza82, 22 February 2017 - 09:16 AM.
Posted 22 February 2017 - 09:29 AM
does not actually matter where they go or how many you have.
Posted 22 February 2017 - 09:58 AM
Posted 22 February 2017 - 10:26 AM
Posted 22 February 2017 - 11:02 AM
Posted 22 February 2017 - 01:32 PM
Depends on the rad.It's also the wrong type for the a series
Posted 22 February 2017 - 05:37 PM
Posted 22 February 2017 - 10:10 PM
Posted 22 February 2017 - 11:56 PM
But again the colour is not really a correct way of choosing.
Cooling system materials should be considered. Cast iron. Brass, steel and aluminium. And maybe some copper.
Edited by nicklouse, 22 February 2017 - 11:56 PM.
Posted 23 February 2017 - 05:30 AM
The later minis didn't use blue.
They should have done. The red will rot iron blocks. It has FA to do with the rad material.
Posted 23 February 2017 - 06:10 AM
Prove it.They should have done. The red will rot iron blocks. It has FA to do with the rad material.The later minis didn't use blue.
Posted 23 February 2017 - 07:38 AM
Edited by Steve220, 23 February 2017 - 07:39 AM.
