Hi can anyone help please! I have a 53 plate mini. When I drive through small puddles or there is a lot of surface rain my mini looses power. No warning lights come on the dashboard. I put my foot hard down on the accelerator and it does nothing for several seconds and then gets power back for a few seconds and then foes the same again. It tends to continue doing this until whatever the problem is either dries out or the water goes! It's been for a diagnostic test and nothing was found. It also didn't do it for them when they drove through a puddle! It doesn't always do it to me but most of the time. Typical it didn't do it for the mechanic though! Csn anyone help. I've spent a small fortune on it recently and hope it's done thing very small as I can't afford to throw much more money at it, although I do love my mini. I'm desperate! Csn anyone help please!
Mini Loosing Power When Goes Through A Puddle.
MichelleCole
, Feb 22 2017 05:27 PM
2 replies to this topic
Posted 22 February 2017 - 05:27 PM
Posted 22 February 2017 - 05:46 PM
The only thing I can suggest is that you have a look behind the grill and at the front and give any wires a good spray with something like WD40 as it sounds like a connection is getting wet and is effectively reducing electrical input. If it was a classic mini I would suggest spraying the distributor cap, and spark plug leads. You may also want to try posting your problem up on www.mini2.com or www.totalmini.com which are sites for the BMW variant mini as this forum is predominantly for classic mini's. They may have encountered this problem and have a better chance of guiding you to the solution. Good luck.
Edited by RedRuby, 22 February 2017 - 05:46 PM.
Posted 23 February 2017 - 06:59 PM
