Hello everyone,
I started with my mini after it is been in storage for 8 years or so.
I need to replace a lot of panels and i wondered what was the best way to go forward.
I decided that i was going to attack the front end first.
I'm replacing both inner wings, wings, front, scuttle, door steps, front floors, sills, a panels, bulkhead cross member, upper dash rail, door skins and possible more.
since the bulkhead wasn't in pristine condition and i decided a long time ago that it would be a good idea to weld up all the holes (which is obviously not) I'm trying to get that done first before ordering a mahoosive amount of panels.
I removed the NS inner wing, A panel and part of the NS cross member the last couple of weeks. After that i tried to fit the new (heritage) upper dash rail to see what i was missing from the bulkhead to get that fixed.
It didn't fit that well and i have an uneven gap to the top of the windscreen surround (most of it is 420 mm wide narrowing down to 413 mm) from the dash rail. Can anybody confirm what the actual width needs to be?
After fixing the bulkhead my plan was to leave the floors and doorsteps in place and offer up the inner wings and scuttle together with wings, front and bonnet to get these into place.
I'm not really sure on this approach because there is some work to do to the inner a posts? and the upper and lower end of the flitch panel? See pictures attached for the current state.
Any advise would be much appreciated!
This is what i started with after 8 years in use as a bin...
I think i miss a section that runs from the a post to the bulkhead which is dsandwiched between the dash rail and the scuttle. Looked thru lots of projects but can't find a decent picture that shows exactly what it should look like and how it is attached to the a post.....
