Hey all,
New to the external hinge thing, and I am not quite sure how to attach the inner and outer a-panel to each other.
Do I weld them along the lip?
Can I epoxy them together?
Any help/advice would be appreciated
Posted 28 February 2017 - 01:48 PM
Hey all,
Posted 01 March 2017 - 01:56 PM
Posted 02 March 2017 - 06:06 PM
Posted 03 March 2017 - 07:04 PM
this is a fun one. make sure you "dry build" everything! ie wings bonnet door and door lock and seals. clamp and tack once your happy with the fit. by moving the A panel in or out top or bottom you will adjust the doors final position. this is one reason why when you look at the cars at shows many outer hinge cars the doors stick out at the bottom becouse the A panels have been rushed and not fitted correctly. good luck and take your time, dont forget to prime between the panels.
Posted 04 March 2017 - 10:11 PM
Posted 05 March 2017 - 12:51 PM
spot weld behind hinges then edges
