Seal Installation
8 replies to this topic
#1 newenglandmini
newenglandmini
  • 646 posts
Posted 28 February 2017 - 10:55 PM
I am in the process of installing the felt/rubber window seals and rubber door seals in my Mk 3 (wind-up windows).  Are these installed dry or is adhesive required?
Attached File  window seal.jpg   16.59K   4 downloads
Attached File  door seal.jpg   12.22K   5 downloads
Edited by newenglandmini, 28 February 2017 - 11:10 PM.
#2 nicklouse
  • 17,945 posts
Posted 28 February 2017 - 10:57 PM
I have only ever fitted them as is.
#3 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 01 March 2017 - 10:04 AM
The bottom part of the seal was glued in when they can from the factory new .. but just like Nick I've never glued them in when replacing them.
Watch out for the bit that's cut away ..it's easy to break it off as you try and install them ...space is a bit limited.
#4 newenglandmini
newenglandmini
  • 646 posts
Posted 01 March 2017 - 02:01 PM
Thanks gents.  I will proceed accordingly.
#5 newenglandmini
newenglandmini
  • 646 posts
Posted 01 March 2017 - 10:41 PM
I noticed that the door seal has a gap.  Can someone tell me what it's purpose is, and where in the door jamb it should be located?
Attached File  DSCN8876.JPG   52.61K   5 downloads
#6 Its a min
Its a min
  • 284 posts
Posted 01 March 2017 - 11:47 PM
If I remember rightly, it should line up with the door check strap .
#7 newenglandmini
newenglandmini
  • 646 posts
Posted 03 March 2017 - 11:50 AM
Upon further inspection,  I've noted that the seal has two gaps, not just one.  Does anyone know how these should be oriented in the door jamb?
#8 jamesquintin
jamesquintin
  • 1,017 posts
Posted 03 March 2017 - 01:01 PM
They go at the bottom of the door, if you have a later car you'll see two indentations on the door step panel, and they line up with them. It's so any water can run out
Q
#9 newenglandmini
newenglandmini
  • 646 posts
Posted 03 March 2017 - 01:50 PM
My car is a '74.  I'll install per your advice.  Thanks.
