Rear Subframe Mounting
Mayfair94
, Mar 04 2017 12:39 PM
Best Answer Ben_O , 04 March 2017 - 01:14 PM
No problem.
These are the ones i use
http://minispares.co...|Back to search
Go to the full post
4 replies to this topic
Posted 04 March 2017 - 12:39 PM
Hi,
Got the rear subframe out yesterday. When I bought the mini as an MOT failure, one of the reasons for the failure was rear mount corrosion. Having a look at the rear mount from below, I can see what looks like 2 plates (see pic) image.jpg 63.84K 25 downloads
Are these previous repairs? I plan on buying the rear valance closing panel with subframe mount repair section. My questions are:
1) Are these two plates previous repairs?
2) Should I remove 1 plate (corroded part) or both?
Cheers,
Chris
Cheers,
Chris
Posted 04 March 2017 - 01:05 PM
They are part of the closing panel and are original.
They should be retained for strength so make sure you replace them.
I believe the heritage closing panels are the only ones to come with these plates. I have used m-machine ones in the past and had to make up the extra plate.
Ben
Posted 04 March 2017 - 01:11 PM
Thanks for your advice Ben, do you mean this panel http://www.minispare...25.aspx|Back to ?
Cheers,
Chris
Cheers,
Chris
Edited by Mayfair94, 04 March 2017 - 01:16 PM.
Posted 04 March 2017 - 01:14 PM Best Answer
Posted 04 March 2017 - 01:18 PM
Cheers, just found it on mini spares. Will add to my order!
