Washer Bottle Bracket -1978 1000
Posted 06 March 2017 - 07:37 PM
Does anyone know which is the correct washer bottle and bracket for a 1978 mini 1000. Mine had a bodge job of a bottle cable tied to the inner wing when I got it. I believe it should go on the bulkhead? Though I have no bracket
Elliott
Posted 06 March 2017 - 07:55 PM
one of these: http://www.leacyclas...om/czh1624.html
might be cheaper else where that's just the first page I found! And yes it goes on the bulkhead next to the wiper motor
Posted 06 March 2017 - 08:01 PM
Posted 06 March 2017 - 08:24 PM
Next question, which size washer bottle, minispares lists 2 different sizes in that style. Also where would the pump be located? Non of the original system is left hence the daft questions
https://minispares.c...r.aspx?1~10~211
Posted 06 March 2017 - 08:30 PM
I'd personally get the bigger one unless your concerned about 100% originality because the other ones so small a few squirts and it's gone
Saying that the bigger of the two isn't much better
Posted 06 March 2017 - 09:47 PM
I think it's the bigger of the two number 10
Fair enough. I'm going for an original look, doesn't have to be 100% so the larger of the two will fit the bill nicely
Posted 06 March 2017 - 11:00 PM
Fair enough. I'm going for an original look, doesn't have to be 100% so the larger of the two will fit the bill nicelyI think it's the bigger of the two number 10
Not sure anyone would know the difference but the larger one is definitely a bit more practical
Posted 07 March 2017 - 06:42 PM
http://minispares.co...WW916.aspx|Back to
this is the bottle you would need, imnot sure the larger one would fit if mounted as original on the bulkhead
Posted 07 March 2017 - 06:50 PM
The one you linked is the bigger of the two shown above and fits fine with the standard air box
Posted 07 March 2017 - 06:56 PM
yes but there is also a larger one still that is mounted on the inner wing on later minis.
Posted 07 March 2017 - 08:11 PM
The one you linked is the bigger of the two shown above and fits fine with the standard air boxhttp://minispares.co...WW916.aspx|Back to
Yeah that one won't fit totally the wrong shape
Posted 08 March 2017 - 01:08 PM
Cheers for all the help guys!
It's actually the larger inner wing mounted bottle that someone had cable tied to my shell
