Air Conditioning Setup For Sale
Posted 12 March 2017 - 06:18 PM
These do not come up very often, you'll not find one on eBay or anywhere else I can find.
This was removed from an spi Jdm import mini that the owner wanted to return back to U.K. Spec,
It was fully working when removed. It includes all the pipework and essential system parts that you will need to fit.
The photos show it constructed loosely on the ground, all pipework has no kinking and protective foam is attached. The connecting joints all work cleanly.
Pipework from the evaporator to the vent is complete and it comes with the dash parts/switches also.
Ready to fit minus wiring (there are wiring diagrams available on the internet to assist you)
Two areas of damage, one to the evaporator to the mounting area and the second in the dash by th radio mount. Neither will impact the working of the system.
I have more photos if needed.
£400ono (same price as previous advert I have found) postage available
Comment or message for more info.
Lawrence
Posted 13 March 2017 - 10:38 AM
Is there any way at all of testing the motors and switches ?
Posted 13 March 2017 - 04:31 PM
I can potentially test the switches for continuity and resistance however there are some parts I cannot test such the thermometer. I can also test the fans for both the compressor and evaporator. I will do some testing and pop the results up here
Posted 13 March 2017 - 05:29 PM
I have just continuity checked everything at it works. There is resistance from the fan resistors in the evaporator and it is clean also. Both fans work for the condenser and evaporator, I have taken videos to support this. the switch units both work also. there are two lights fitted to the fascia, one of them has a bulb blown however the second has continuity. the bulbs are to illuminate the switches and to give an ac on warning light. the expansion valve "switch" shows no continuity however it is designed to break the circuit to the compressor when the system is empty, I am therefore unable to test this "switch"
I will upload the photos and videos when they are on photo bucket.
hope that answers all of your questions.
Posted 13 March 2017 - 06:38 PM
http://vid1111.photo...0313_165212.mp4
http://vid1111.photo...0313_164232.mp4
http://vid1111.photo...0313_165607.mp4
Edited by lawrence, 13 March 2017 - 06:40 PM.
Posted 23 March 2017 - 09:29 PM
Posted 31 March 2017 - 09:42 PM
pm sendt
