My New Mini, British Open Classic. Ongoing Road Project!
#31
Posted 02 June 2017 - 09:04 AM
I'm not putting a glovebox in and I'm thinking of making rings then sand them down at an angle so the gauges face the driver. I've ditched the gauges that came with the car as I thought they were totally useless, water temp, oil temp and an ammetter but I've ordered a small rev counter and oil pressure gauge that I'm going to install with my air/fuel gauge.
#32
Posted 02 June 2017 - 11:11 AM
#33
Posted 02 June 2017 - 03:28 PM
#34
Posted 03 June 2017 - 03:31 PM
Roof works, not sure if that's a good thing or a bad thing since now I really want to drive it and it's still in bits. Hopefully it will give me the motivation needed to get me to work extra hard.
My carbon headlight surrounds and moustache are here but need to pay duty so should get then tuesday so that's something to look forward to.
#35
Posted 12 June 2017 - 04:31 PM
Been working on dash when I've been bothered. Still got stuff to do to it but it's looking ok so far.
And these beauties
Progress will be slow from now on as I've got other things that need sorting.
#36
Posted 14 July 2017 - 12:21 PM
Hoping the weather holds up next week, I want to finish off fitting the rear arches. Sort the rust where the rear bumper mounts to, refit tank and other boot things.
#37
Posted 20 July 2017 - 07:20 PM
Decided to try and sort the rust around the holes the bumper mounts to so started wire brushing it and that just revealed that the rear valance was full of rust so need to sort that now as well.
I'm on holiday for the next 10 days so depending on weather I'm hopefully gonna make some decent progress on it.
#38
Posted 21 July 2017 - 05:17 PM
I banged into my arch yesterday and 3 of the 4 brackets I'd glued down with tiger seal popped off so I've reglued them and will fiberglass over the top of them once its dry to hopefully not have the arches falling off again. What's weird is that I originally glued one bracket down so I could mount that to the body then do the other brackets and that's the one that is stuck to the arch solid.
I now can't do much as the rear is up in the air and I have to wait for the parts from minispares to show up to finish that and I can't do much to the front end because I can't lift that up so all I can do is work on the middle bit so I've been working on my mirrors and dash.
#39
Posted 21 July 2017 - 06:49 PM
#40
Posted 22 July 2017 - 01:14 PM
Thanks mate luckily I'm not looking for perfection in this build, it already takes me at least two attempts at whatever I'm doing because I always screw up the first time and even then I'm usually not completely satisfied so really my main thing is to have a reliable mini that runs well so I can actually enjoy driving it.
#41
Posted 26 July 2017 - 05:53 PM
What I want to do is wire brush all the surface rust off the panel and spray "weld through primer" on it before tacking the rear valance in. I've not had much luck with trying to do spot welds or plug welds when I've tried to weld before so I was just gonna run a few welds along the lip and weld up the outside of the closing panel. Or should I drill a few holes and try plug welding it?
To be fair I'm fairly happy with the fit, lines up quite nicely with the closing pannels and the 3 mounting holes for the bumpers are about right.
Not done much to it over the last few dsys, replaced the rear brake lines and used stainless steel brake unions. Replaced the shoes and springs just because they're cheap to replace and a few electrical things like riveting some earth points in the engine bay.
#42
Posted 26 July 2017 - 09:28 PM
#43
Posted 27 July 2017 - 12:39 PM
http://www.mig-welding.co.uk/
#44
Posted 29 July 2017 - 05:04 PM
#45
Posted 12 August 2017 - 04:27 PM
My daily decided to break down last week and without knowing how long it will take for me to fix it I figured that I'd bolt everything back onto the mini and use that the now so this project will take a wee pause and I'll do the rest at some point in the future. Done a decent bit of work to it, over the last few days rear brakes have been rebuilt and bled but the fronts will need doing, both window channels have been replaced with a stainless unit so both windows now go up and down but the electric windows will need to wait. Fitted my dash, cut the wing for the wheels and bent a new lip for it and put all the bits back on it etc. Didn't really have time to take pictures of the progress and I'm not entirely happy with the way some things have turned out but I do like the way it looks even with the sportspack front arches still fitted instead of the miglias.
