Which Arches Will Go In The Same Holes As The Standard Rover Arches?
Posted 14 March 2017 - 07:52 PM
Posted 16 March 2017 - 03:10 PM
My brother used the plastic ones off mine as a template.
Fit rivnuts too as you may want to remove them in the future for cleaning and such. 😀
What size wheels do you want and what do you have now? 6x10 sit nicely and don't catch...
Ben
Edited by MacGyver, 16 March 2017 - 03:12 PM.
Posted 16 March 2017 - 06:12 PM
I have the standard black plastic arches on my mini but I want wider wheels and they aren't going to cover them enough. So what arches will fit without having to modify the actual bodywork? Also what's the widest set of wheels I can get that won't catch? Thanks
these are the ones : http://www.minispare...r-classic-mini/
really good quality, had them on my first one
Posted 18 March 2017 - 07:57 AM
Posted 18 March 2017 - 08:00 AM
Posted 18 March 2017 - 08:31 AM
When they came out of the box, is the colour/quality good enough to be used without spraying them.? Is the moulding plastic really black and flawless, or would you recommend spraying black.?
Posted 18 March 2017 - 09:34 AM
Have a look at the ET offset to see how much they will be sticking out.
Try: willtheyfit.com when you get the numbers...
Ben
Posted 18 March 2017 - 01:08 PM
From what I can remember they were good straight out the box. A good t cut and then a proper polish would make them look painted imo!
Posted 19 March 2017 - 10:21 PM
Think I'll order those arches tonight as well. Thanks man
Posted 20 March 2017 - 08:26 AM
According to willtheyfit.com
So i believe you'll be OK, but maybe you'll touch the wings at the front so might need mods but maybe someone will know on here that has fitted some.
Posted 21 March 2017 - 07:46 PM
I have those minispares ones (from a long time ago) and I never painted them, they are fine from the box - they do polish up good too as Will said. Fitting wider wheels I had to modify the metal on one arch, not the other... go figure!
