Whats The Best Product For Shot Blasting
18 replies to this topic
#1 rhys-89
rhys-89
  • 1,549 posts
  • Local Club: minifreekz
Posted 18 March 2017 - 03:05 PM
Hi all whats the best product for use shot blasting steel wheels ? Thanks all
#2 Spider
  • 13,884 posts
Posted 18 March 2017 - 06:53 PM
I think you are looking for 'abrasive blasting' rather than 'shot blasting'?
Sorta similar processes but for quite different outcomes!
Sot blasting is sometimes used for reducing surface raisers and the likelyhood of cracking, where as abrasive blasting is usually used for cleaning stuff up, especially when rusted.
#3 rhys-89
rhys-89
  • 1,549 posts
Posted 18 March 2017 - 07:16 PM
Yeh the latter cleaning stuff back to metal to re paint whats the best product for this ?
#4 Spider
  • 13,884 posts
Posted 18 March 2017 - 07:25 PM
If it's rust you'd like to clean up, along with paint, Garnet is good, but go easy.
If it's just paint you want to take off, Soda is excellent.
I don't do my own stuff. I have it all Soda Blasted first, then ONLY what's needed were there's rust (or in the case of bodies, filler), I have these areas spot basted with garnet.
#5 rhys-89
rhys-89
  • 1,549 posts
Posted 18 March 2017 - 07:52 PM
Thanks im looking to go through paint and the odd bit of rust on the wheels never intended to use it for the body shell just on small parts that are hard to get to with wire brush and wire wheels. And to make life easier :)
#6 Daz1968
Daz1968
  • 2,058 posts
Posted 18 March 2017 - 08:25 PM
I have just bought a small cabinet and have some aluminium oxide grit. It works fine but if the garnet is better will try it next time I get some
Edited by Daz1968, 18 March 2017 - 09:26 PM.
#7 RooBoonix
RooBoonix
  • 1,224 posts
Posted 18 March 2017 - 08:29 PM
At work we use aluminium oxide on everything. Brings stuff up a treat, but be careful on weaker/more delicate aluminium parts and especially brass as it will just eat them away if you're not careful. Steel and cast aluminium are normally fine, just try and keep the distance between the nozzle and part as much as is practical when blasting the softer parts.
We also have a vapour blaster which we use on mostly aluminium or brass parts, which I believe has nylon bead but I may be wrong. The vapour blaster leaves an unbelievably uniform finish on brass parts, and also does a nice job of aluminium after being previously cleaned/sand blasted.
Edit: I also read somewhere that you have to be careful with the way you dispose of the used aluminium oxide.. but I'm not sure why as I haven't looked into it.
Edited by RooBoonix, 18 March 2017 - 08:30 PM.
#8 rhys-89
rhys-89
  • 1,549 posts
Posted 18 March 2017 - 08:37 PM
Thanks alot guys aluminium oxide it is then
#9 RooBoonix
RooBoonix
  • 1,224 posts
Posted 18 March 2017 - 08:46 PM
Let us know how you get on, as mentioned in your thread about the new compressor you have.. mine is of a similar spec, HP and CFM wise, so I'm interested in how well it performs at blasting. If it works well then I may build up an enclosure myself.
Edited by RooBoonix, 18 March 2017 - 08:46 PM.
#10 Daz1968
Daz1968
  • 2,058 posts
Posted 18 March 2017 - 09:09 PM
Air required is down to nozzle size but blasting is air hungry, I have a Clarke industrial 3hp that keeps up ok, make sure you have good water traps as well.
#11 rhys-89
rhys-89
  • 1,549 posts
Posted 18 March 2017 - 09:20 PM
Yes will keep posted and some before and after pics too :) looking into inline water traps as well as the aluminium oxide hopefull be hear and using by wednesday :)
#12 dean
dean
  • 283 posts
  • Local Club: EDMC
Posted 19 March 2017 - 09:55 AM
i have used aluminium oxide in 2 different grit grades, fine woks well to make things have a good clean finish , carb body alloy parts. etc  where the course is better at removing the bulk of rust an paint.
you will find it hard to remove powder coat, it does take a lot to remove.
i have also used normal paving sand from wickes, its cheap for a bag, http://www.wickes.co...r-Bag/p/220201.
if its damp at all, i put it in a old roasting tray and put it in the oven to dry it out before putting it in the blast cabinet,
i also connect a hoover to the filter side ( breather) of the cabinet, it helps to remove the fine dust in the air in the cabinet , which helps you see what your doing.
also stick these to the inside of your glass, they will get hit by the grit and start to make them go frosted over time,  but its easier to change them than the glass.
http://www.ebay.co.u...s-/221857710075
its just a example link, you be able to find them cheaper, as it just a thin film , double sided taped to the inside of your glass.
#13 rhys-89
rhys-89
  • 1,549 posts
Posted 23 March 2017 - 06:20 AM
My aluminum oxide turned up yesterday so had a quick go. Love the result.
#14 r3k1355
r3k1355
  • 585 posts
  • Local Club: East Anglia
Posted 23 March 2017 - 10:05 AM
What compressor are you blasting with?
#15 rhys-89
rhys-89
  • 1,549 posts
Posted 23 March 2017 - 11:24 AM
My new sgs 100ltr
