Which Pipe
Posted 19 March 2017 - 08:13 AM
Which pipe goes on which part of the heater box/matrix?
I didn't take a picture before I took them off.
1 straight pipe, 1 shaped pipe.
Nic
Posted 20 March 2017 - 11:51 AM
If you mean the water pipes doesn't the length dictate which one goes on which side?
Posted 20 March 2017 - 04:32 PM
Interesting I made the very same mistake so will be watching this with interest.
However I think it is in from the water pump to the heater at the bottom and out to the control vale at the top.
Posted 21 March 2017 - 04:19 PM
That's how the pipes fit best:
In at the bottom of the heater from the water pump. Out at the top of the heater to the control valve.
Posted 21 March 2017 - 04:24 PM
there seem to be a few different connections from what I remember.
but the feed should go in to the bottom of the matrix and the return out of the top.
this aides self bleeding and reduces air locks.
Posted 23 March 2017 - 10:44 PM
Mine are front and back rather than top and bottom and in the passenger side.
Pipes are not connected the other side as no engine at the moment so can't tell which would naturally reach to which.
Picture of the natrix I have IMG_6695.PNG 399.91K 4 downloads
Posted 23 March 2017 - 10:57 PM
I'm pretty sure it doesn't matter, but move to injection section where someone can check
FS
Posted 26 March 2017 - 07:35 AM
The link comes up blank though.
I've been on minispares and the description of pipes is 1 straight.1 shaped. Which is what I have.
I'm sure once the engine is fitted and cooling system connected it will become clear as one of the pipes will probably not reach the further connector of the matrix.
I'm just trying to do it the other way round so would be easier to know and fit now.
Nic
Posted 16 February 2018 - 02:34 AM
Did you ever figure it out?
Posted 16 February 2018 - 04:00 AM
I was reading this recently and it suggests you want the hot going in the back connection and out the front.
https://www.calverst...g-how-it-works/
Fitment of an auxiliary radiator will help if the two-core is not enough - say on a race or rally car. Use the matrix out of the heater box, and plumb this in going from the heater tap take-off, into the back fitting of the matrix, then out of the front fitting and into the bottom hose. If you pass the water coming out of the heater tap take-off down the front of the matrix first, you will be blowing hot air across the water going back out of the matrix and into the engine.
