Welder Help No Feed
Posted 20 March 2017 - 07:21 PM
Thanks Jon
Posted 20 March 2017 - 07:22 PM
Posted 20 March 2017 - 07:28 PM
We have the opposite issue when the drive motor runs continually. Now this is a different machine but i reckon its down to something being corroded either in the motor or the PCB. Our workshop does get damp plus i do know it worked fine before hand, just had an issue with the pressure clamp.
Check the trigger mechanism first to make sure there is nothing amiss inside there, very straight fwd to do. After that then it needs someone with a tester to check there is power going to the motor.
Posted 20 March 2017 - 07:31 PM
Posted 20 March 2017 - 07:33 PM
Have you set the correct tension on the wire?
Motor feed is not turning he said. The feed roller will turn no matter what.
Posted 20 March 2017 - 07:36 PM
I've seen your fault on a welding forum I think it was something to do with the motor isolation ??
Tension....tried it extremely loose and with no wire just to get the motor turning but nothing. Just the relay ??!!
Posted 20 March 2017 - 07:38 PM
Thanks. Yes the trigger operates the relay fine so assume that's ok. It's just come out of the wrapping.
To me its either the relay not working correctly or a power feed issue. You need a sparky to check the feed from the relay to the motor at the very minimum.
Posted 20 March 2017 - 07:40 PM
Posted 20 March 2017 - 07:42 PM
Thanks I'm gutted. I've had it for so long and never even used it !!
Thats the problem. Even though a shed maybe relatively dry moisture can still affect electronics and the fact its never been used it may have come from the factory like it.
Posted 21 March 2017 - 02:59 PM
Posted 21 March 2017 - 07:14 PM
Cool, glad its working.
Posted 22 March 2017 - 11:45 AM
Posted 22 March 2017 - 01:21 PM
It appears I have a fault on position 2 of the heat setting! 1,3,4,5&6 workgreat but if you select 2 the feed motor doesn't turn !
Now this could be down to either an internal fault or the lack of use
